Ok , I admit that the numbers are really bad
The stang is totally stock now ; since I am planning on modding it with K&N filter + SCT2 custom tune for the eurosuper 95 octane fuel , I decided to take a dyno run before the mods .
The results are horrible , I think mainly because our fuel has too many octane . In fact there is a big drop around the 4000 rpm probably for this reason .
Conversions for your units of measure :
1kW = 1,34 HP
1Nm=0,74 lb ft
so I have
max torque 261,8 lb ft at 2878 rpm
max HP 229,3
max rwhp 179,7 at 5475 rpm
but the curves are really bad , as if the motor cannot reach its maximum power , in fact at 5500 rpm we see no drop .
We did not go over 5500 rpm to avoid damage to the cat for the lack of ventilation under the car : the fan was pointing at the front of the car .
Anyway , I would like to know your opinions on this dyno .
If someone has a dyno chart of his 05 V8 stang and can post it for comparison , I would be very glad of seeing it on this tread ; better if not modded so we can have more interesting comparison.
All HP data are SAE , and the dyno tester is a very serious company that makes the dynos for local races with ferrari , maserati , etc .
Thanks to everybody
Steel
1kW = 1,34 HP
1Nm=0,74 lb ft
so I have
max HP 229,3
Thanks to everybody
Steel
