  • 1994 - 1995 Specific Tech
Please Need Some HELLLPPPPPP!!!!
  • Thread starter Thread starter BigNastyGT
  • Start date Start date Nov 1, 2005
BigNastyGT
  • Nov 1, 2005
Well guys i got a little problem that im getting all kinds of answers from.......well i have a 94 Auto Gt Vert with a 306......the motor has maybe 3,000 miles on it with underdrive pullies, mac o/r Hpipe, upper and lower intake,E303 cam,and somemore little stuff but heres the prob...sometimes with i give it alot of gas and stand on it mostly at high speeds it shoots out a little cloud of smokeamnit: ....its not all that bad but its kindda worrying me....im changing the oil in it tomorrow....but the oil now isnt milky so im not sure if its a head gasket...but if u guys could please help me out and let me know something!!!!! THANX!!!!!
MLC Stang
210
Atlanta, GA
Nov 1, 2005
  • Nov 1, 2005
More info, please.
For starters... what color smoke?
White = burning water/coolant (leaking head gasket?)
Blue = burning oil (oil getting past rings or valve seals)
Black = unburned fuel (running very rich)
BigNastyGT
  • Nov 1, 2005
Its def not black im not sure if its blue or white i think its white bc i think its burning some radaitor coolant
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 1, 2005
  • Nov 1, 2005
Only way coolant can get into the cylinders is through the lower/upper intake manifolds, heads or the block. My guess is you have a bad seal, either the head gasket or intake manifold.
Yank the spark plugs and see which is getting the coolant.
A coolant pressure test w/ all the plugs removed might show you the leak.
Scott
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
please help! not a typical coyote swap
  • sarver24
  • Nov 15, 2024
  • Other Auto Tech
Other Auto Tech Nov 15, 2024
manicmechanic007
What in gods green earth happend to my N/A 2.3?
  • Piranahbite
  • Mar 24, 2024
  • 2.3L (N/A & Turbo) Tech
2K
2.3L (N/A & Turbo) Tech Jun 1, 2024
Piranahbite
E
Well now what?
  • Ethereal_Zer0
  • Jul 23, 2023
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2023
Ethereal_Zer0
E
N
Paint and Body Body Surface Rust.. Need Help.
  • Neptuned
  • Sep 9, 2022
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2022
General karthief
