plugged cat
  • Thread starter Thread starter ebiggs1
  • Start date Start date Jul 30, 2007
E
ebiggs1
268
Spring Hill, Kansas
Jul 30, 2007
  • Jul 30, 2007
What are the symptoms of a plugged cat?
bill302
2,131
alabama,gadsden
Jul 30, 2007
  • Jul 30, 2007
read article below for symptoms of plugged cats and if there plugged you might need to check air pump, air valves and hoses that supplies air to the cats...prolly not working properly...
http://www.aa1car.com/library/converter.htm
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jul 30, 2007
  • Jul 30, 2007
When I plugged mine I had no power. Soon I blew some vacuum lines off because the exhaust had no where to go. melted the vacuum line to the MAPS sensor. then my engine computer went into limp mode and flooded the heck ot of the car. Couldn' drive the thing.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jul 30, 2007
  • Jul 30, 2007
Symptoms of a clogged cat: Lack of playful activity, sulking, reduced food intake, and no fecal matter found in litterbox.
Sometimes plugged cats will heat up enough to glow red, and there will definitely be a notable loss of power. You might also notice a funky smell coming from the exhaust/tailpipes. Go WOT a few times at night, then take a quick peek under there while it's still running. Also, pop the hood and take a look down from the top, if you're running the stock H-pipe with four cats, so you can see the top two that aren't easily visible from the underside.
Smitty
44
Mansfield OH
Jul 30, 2007
  • Jul 30, 2007
cut 'em off & have a local shop replace the area with regular exhaust pipe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
Electrical Spark Plugs
  • jimzzilla
  • Feb 24, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 28, 2026
jimzzilla
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
