  • 1994 - 1995 Specific Tech
Polishing Wheels!!!!!!!
  • Thread starter Thread starter 91LX_5L
  • Start date Start date Feb 26, 2004
First Prev 2 of 2
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Feb 29, 2004
#21
  • Feb 29, 2004
  • #21
You need this spiral sewn wheel for the tripoli..Again this is the MOST important compound when transforming from the paper
http://www.shinesbrite.com/compounds.html
Here is a link for some white rouge.
Sears or HD should have it.
As far as the calipers..DONT worry about getting them mirror...I didnt on mine. They get too dirty outside anyway. A nice silvery shiny is fine.
Look at the fuse box cover here..This was done with tripoli, then rouge..NO MOTHERS.
RC
blown93feature
151
living on edge like the motor
Feb 29, 2004
#22
  • Feb 29, 2004
  • #22
the most important step to take when transforming from a once nonpollished surface is wet sanding than to compond out the the balance of fine scratches.Paul if your getting scratches you are most likely picking up debris from some where.Rc is right in the wheel ap for that product for buffing out whats left for fine scratches but keep in mind that if you don't keep enough material on the wheel you will to scratch due to high rpms.Plus when using this type of wheel use it on the edge like if you were going to cut a piece of wood not like a buffing wheel for paint.
paul,I want you to try this product with a small wheel so you can handle it easier and will be messy but you will like the results.Apply a generous amount to a rag apply to your roter then wheel the piss out of it try to keep it wet for a while than stop applying more pollish and let the wheel start drying out the pollish by repeated stokes across the rotor.take a clean soft cloth and rub off exsess.use mothers after to take out any cloudyness or blemmishes.
blown93feature
151
Feb 29, 2004
#23
  • Feb 29, 2004
  • #23
here are some before and after pics of the driveshaftmake sure you work the pollish until the shine starts comming through.
blown93feature
151
Feb 29, 2004
#24
  • Feb 29, 2004
  • #24
charlie and I did my intake. this was done with a dremmel and speedy on the a/c then mothers by hand.
94GTLaserRC
11,178
Feb 29, 2004
#25
  • Feb 29, 2004
  • #25
Blown 93..Those TFS intakes are the nicest looking intakes when polished.. (the Cobra's look nice too, with some red and black colored plates)
RC
blown93feature
151
Feb 29, 2004
#26
  • Feb 29, 2004
  • #26
RC
thanks man ya they do shine up nice, my hats off to charlie for the job he did.I was looking at your intake ealier I believe thats the same one chalie has and they look awesome all pollished up like that changes the whole motor.I didn't realize that paul was trying to polish his callipers i thought he was talking about rims and I see that you have as well man i am falling behind
paul take some pics of all that you have done I would like to see your hard work...
Killercanary
The car that set the bar.
Altoona, PA
Feb 29, 2004
#27
  • Feb 29, 2004
  • #27
Here you go. You'll notice you can actually see the camera in most of ther pics. Some of the pics show what the caliper looked like before. I got these from a junk yard and they were really oxidized, and one was painted red so I had to get as much of that off as I could. I cleaned up the brackets and sprayed them with black engine paint. I took an extreme closeup so you could see the very fione scrathes. You can barely notice them until you get as close I did with the camera.
Killercanary
Altoona, PA
Feb 29, 2004
#28
  • Feb 29, 2004
  • #28
Here's the rest...
Here's my inlet elbow...
91LX_5L
1,943
British Columbia
Mar 1, 2004
#29
  • Mar 1, 2004
  • #29
So what polish works better on polished wheels that BILLET polish? If not im using that mothers in the red can...how much do you apply? just enough to cover the metal lightly or do you gob it on pretty good?
ps: Canary pics dont work
blown93feature
151
Mar 1, 2004
#30
  • Mar 1, 2004
  • #30
91lx,use enough to get an area of about two inches wide and 3 to 6 inches long and work the paste back and forth.I personaly like the latest stuff that mothers has and thats the billet pollish but either one works great.
Paul, picy no worky try again.
94GTLaserRC
11,178
Mar 1, 2004
#31
  • Mar 1, 2004
  • #31
Your pics just came up as a red x to me!
RC
Killercanary
Altoona, PA
Mar 1, 2004
#32
  • Mar 1, 2004
  • #32
Hmmm... I can see them. Lets try again...
http://forums.stangnet.com/attachment.php?attachmentid=19457&stc=1
http://forums.stangnet.com/attachment.php?attachmentid=19458&stc=1
http://forums.stangnet.com/attachment.php?attachmentid=19460&stc=1
http://forums.stangnet.com/attachment.php?attachmentid=19461&stc=1
http://forums.stangnet.com/attachment.php?attachmentid=19462&stc=1
Killercanary
Altoona, PA
Mar 1, 2004
#33
  • Mar 1, 2004
  • #33
I know this one works...
onebad95
Sherriff of Bling King County
Jul 22, 2002
1,237
At the end of the track waiting for you !!
Mar 1, 2004
#34
  • Mar 1, 2004
  • #34
Paul,
I can see something yellow in the reflection, Please tell me that's not your car. I thought you were gonna paint the car white. After all, White does knock off 2 tenths in the 1/4......
J
jachmar15
12
#35
  • Mar 1, 2004
  • #35
weenol works great or never dull. have to be careful with the never dull though you rub to hard and it will scratch the wheels
blown93feature
151
Mar 1, 2004
#36
  • Mar 1, 2004
  • #36
hehehe chaz ! Paul if you ask me, I think those calipers look awesome.The only way to get all the scratches out is to wet sand and then buf with reducing grit compound.I would if i was you and didn't like what I was seeing try to use the speedy like I said earlier.That stuff has a solvent in it that will react to aluminum when applied and then the heat will open the poars and allow the aluminum to actually move and fill , clean poars out and it has a reducing grit that breaks down with repeated motion.If you want use quad zero steel wool to apply first so it isn't so messy then use the machine to work it in.Keep at it until you see the shine come threw.
P.s I think the darn things look good and if you aren't happy with them you can always give them to me...
94GTLaserRC
11,178
Mar 1, 2004
#37
  • Mar 1, 2004
  • #37
What are you complaining about DOOD!!! They look great.. BESIDES, you dont even see the tops..only the fronts.
RC
blown93feature
151
Mar 2, 2004
#38
  • Mar 2, 2004
  • #38
RC
hehehe oh ya I figured that I should finish what I started
First Prev 2 of 2
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
