Polyurethane Trans Mount???
TwoToneHatch
170
New Jersey
I was given a prothane polyurethane transmission mount when I did my T5 swap. I'm just now learning that you shouldn't use a polyurethane trans mount without poly or solid motor mounts. The car is my DD '89 GT so will I be able to sneak in a set of poly motor mounts by using a piece of wood and a jack or is there someone that makes a decent stock replacement trans mount?
There's no easy way to replace motor mounts ... its not hard its just that you have to remove a few things to get the motor lifted to where you can remove the old mounts but id go poly motor mounts I have solids now and they suck I hate them im going back to poly
