Absolutely!!!!!!!! I downloaded the M-2300-K brake kit installation instructions and used the parts list as a checkoff sheet. I didn't have to buy the exact part numbers on the list but at least you will know what you need and what you have left to buy once you start checking them off.
Do the research man.......I will give you some links that might help you in you conversion. This is originally from a PM I sent to another member here:
Just to warn you, this is going to a long response. I went with all new parts except for the booster which I got off of Ebay for $45 and the '95 spindles which I got for $150 locally. I bought new hubs from Ford which cost $75 each. I ordered the 5 lug SN95 length axles from summit which are Alloy USA brand for $209. The wheels I price matched to $95 each at summit, the price came from stangsuspension.com and saved about $65 on shipping. I ordered new hard lines with the correct fittings for the rear from Daves Mustang Parts off Ebay for $50 (to make my life easier so no cutting lines and re-flaring). The front 13" rotors are
Brembo brand which I got for $145 for the pair off of tire rack. The rear rotors I got with the M-2300-M kit which came with rear rotors, rear caliper brackets and dust shields for $170 from Summit. The rear calipers are from Summit and the fronts are the Mach 1 PBR calipers and I found those at Stangsuspension.com for like $165 I think. The SS braided lines I got from Maximum Motorsports. The Cobra M/C I got from ebay for $95 brand new. The E-brake cables I got from Summit. The hardware I got from Ford....oh yeah, you will need to get new spindle nuts (most likely from Ford) because they are one time use pieces and they were about $20 a piece. You will also need a 3-2 master cylinder conversion and I would suggest getting that from Maximum Motorsports too (easy to install but it was like $40. To me it was worth it just for ease of install) I also installed new FRPP A-arms while I was in there and I price matched them at Summit from stangsuspension for $179.
I will tell you the two most pain in the ass part of the whole installation for me......
1. The Brake booster because it is quite a bit larger than the stock one and the upper mounting nuts are a pain to get too because of lack of room to work under the dash.
2. The E-brake mods and attaching the new front E-brake cable to the handbrake assembly. We notched the bracket a bit to make it easier to move the cable into position.
My thread to the brakes is:
http://forums.stangnet.com/showthread.php?t=651765
My advice is, figure out what wheels you want to go with so you can choose what length axles you need to run. I chose 17x8 so I went with SN95 length. If you go with 17x9 it is advised to go with stock length axles and use the bracket from
http://www.northracecars.com/catalog/brakes/brakes.htm .
Here are some links that might help you a bit in your parts seach and your install.
http://svo73mm.cjb.net/
Here are the 3 installation insructions I went off of which I would advise you study hard to make installation go much smoother so you know what to expect.
http://www.mustangcentral.net/tech/brake.html
http://www.mustangmotorsport.com/underhood.html
and this is the link to the actual FRPP M-2300-K cobra brake installation instructions (warning: for the most part, it is fairly vague but it does have some good pictures in it.):
http://www.fordracingparts.com/downl...htM-2300-K.pdf
I would use the M-2300-k parts list as a check off sheet so you know what to buy and so you know what you already have. It helps immensely.
For the ball joint spacer, just use a stack of 3, 5/8 ID thrust washers and it should space the castle nut up enough so you don't run out of threads if you use a fox ball joint. The total space should be around .330" and that should be about what 3 washers would be.
Check out those installation instructions (all 3 of them) and if you have any more questions, feel free to email me at
[email protected]
If you need more detail let me know I and I will be happy to help you further.
I am sure I forgot some stuff but this PM is about long enough for now.
Just know what you need before you start buying parts and do yourself a favor and go with '94-'95 spindles.
As I said before, if you have ANY questions let me know!!!!!
Sincerely,
Justin
PS-The brakes are the best upgrade for the money so congrats on wanting to be able to stop.
START READING!!! Also, print out those 3 installation instruction for quick reference!
