Popping in front end
bud041277
Anyone have an idea what may be causing my fornt end to pop sometimes. I have a 1995 Cobra with 89k and it is babied. It does have some mods but none to the suspension. I think it may be the ball joint or tie rod end. Anyone have an idea?
When does it pop? Going forward and accelerating, stopping, turning, high speed, low speed.....? Backing up?
if it makes a pop-pop-pop noise while turning, i'll bet it's the cv joints.
Just to clarify: that's only if while turning and going forward. If it happens while going backwards, it's the kanoodler valve not reciprocating the neolite fluid back to the reluctortangs.
You left out the muffler bearings, the transducer in the capaciter could be causing the PCM to make popping noises because its low on blinker fluid....
:lol: :lol: :lol:
I wish I could have beat you to the punch hissin... Anyway to clarify our cars dont have CV joints. That is on front wheel drive cars and IRS vehicles like the 03-04 cobra. Now to bud041277 it could be the struts or lower ball joints. The tie rods would cause a noise when you move the steering wheel, similar to a rubbing noise. I want to go a step forward and say its most likely your struts because the lower ball joints would cause more of a noise when turning the steering wheel as well. Go to your vehicle and push down multiple times on the front passenger side and then the drivers side, see if you can duplicate the noise by doing just that. Also the obvious thing would be to check if your struts are leaking. Try these things and let me know what happens and I will see what I can help you with from there. I mostly do front end work at work so solving NVH problems is starting to become an art to me.:D :SNSign:
