What is the secret to a good port match between an intake and cylinder heads? I have done this using gaskets but have been told doing it that way is not always exact. I have heard to bolt together the parts and use a vacuum cleaner to suck air thru the exhaust ports and spray paint into the intake. This is suppose to leave an outline of the material that needs to be removed. Does this sound right or was I dreaming? Anyone have any other good procedures other than using the gaskets?
I put the heads on with the gasket,taped my intake gasket to the heads with scotch tape. Then put super glue on the face on the intake and set it in place and torqued it down. Let the glue drie and it will overcome the strength of the tape and when you lift, you have your gasket exactly were it will be. I also painted to face of the inatke firtst. That way you can scribe the intake and take of the gasket.
