Hey guys,
I've been looking at various different routes to pursue for getting a new TB for my little build up . . . seems I don't have much choice but to bite the bullet and pay up as they're all expensive, but I did find a "bargain" that I might consider buying.
It's a ported 65mm throttle body; I guess it'd be easier to just cut and paste the ad:
"65MM BBK/EDELBROCK Throttle Body and EGR Spacer that was PORTED for more performance. The blade shaft was reduced and Stainless Steel countersunk screws were applied. Next, the (bore opening) was then opened to 82mm and tapers back down to 65mm and then throttle body was completely cleaned inside and out. This allows this throttle body to flow better than when it came from the factory by reducing turbulence from the blade shaft which increases airflow. Next, the throttle linkage was painted gloss black to get rid of the bright gold that comes original from BBK. This throttle body looks great and flows better than new so whats not to love. This also comes with a matching 65mm EGR Spacer plate."
Yeah it sounds good, but I'm not so sure about this porting, and in fact the TB/EGR spacer is rather cheap ($120) if it's really that great. I have heard that turbulance in the intake charge can be desirable and increase HP/efficiency, and I suppose that maybe this port job could create a venturi effect and help out?
One of my buddies thinks that I should steer clear of this TB, but as knowledgeable as he is of building motors I don't thnk he knows a whole lot about F/I. All the same, my H/C/I swap and intake/ FI upgrades have gone over budget, and any more money that I spend will likely leave me eating ramen noodles till the end of my semester; not to mention that my shocks/struts are blown so I'll likely wrap my car around a tree before I get used to the >100hp I expect to pick up if I don't address the suspension as well.
My point is, I can't afford to waste money, and I'm wondering if I should take a chance on this TB . . . oh and BTW it says BBK/Edelbrock . . . wtf? I thought these were 2 completely seperate companies, am I missing something?
One of my buddies thinks that I should steer clear of this TB, but as knowledgeable as he is of building motors I don't thnk he knows a whole lot about F/I. All the same, my H/C/I swap and intake/ FI upgrades have gone over budget, and any more money that I spend will likely leave me eating ramen noodles till the end of my semester; not to mention that my shocks/struts are blown so I'll likely wrap my car around a tree before I get used to the >100hp I expect to pick up if I don't address the suspension as well.My point is, I can't afford to waste money, and I'm wondering if I should take a chance on this TB . . . oh and BTW it says BBK/Edelbrock . . . wtf? I thought these were 2 completely seperate companies, am I missing something?
Either way.
