Ported heads
stevesLX
373
cincinnati
I have been having a lot of valvetrain noise and heve done everything possible to get rid of it with no such luck. I seriously doubt that this is causing my noise because this would be more of an exhaust leak but its worth a shot. My heads have been ported and my old headers where they hook up to the heads theopenings were bigger than the openings on the new ones I installed. They are still 1 5/8 just like the old ones were but the old ones I guess maybe someone used a dremel and opened up the holes some more to match the heads that were ported. Could this maybe be causing my noise. I have felt all around the headers as best as possible and cant feel any obvious leaks.
A stethascope may help you pinpoint where the problem is, but its a crapshoot.
I had the same problems and I fixed it with some copper exhaust manifold gaskets and a new header bolt kit, the bolts have an allen head in the center and are a smaller head on them so you can get at them easier.....the kit also has a socket with a rounded allen wrench built in. Works great, no more leak ticking noise is gone!!!!
