A'ight. My engine just blew up and the summer's wasting.
I'm building fast and cheap, here; all I have to work with is about $300 and a VERY clean '86 H.O. New heads are not an option; I'm blowing what disposable cash I've got on a cam, timing set, gaskets, and enough beer and pizza to build this sucker in 2 weekends.
FWIW, I"ll be putting in an e303 cam -- the .498/.498 is as close to the .500 clearance I'll get with the flat-top pistons -- and bolting on my dual-quad tunnel ram rig intake. This winter (which starts in October), I'll be stroking to 331 with KB pistons and an X cam and slapping some new heads on top. For now, there are 6 weeks of summer left in the Northwest (if we're lucky), and I want to spend the last five of them eating Rice.
The E6 heads have fairly beefy intake ports; they almost match the gasket on the sides. The tops and bottoms of each intake port I can shave 3/16", and I can grind out the hump inside each intake port (swirl thingy) and of course the emissions nipples on the exhaust ports, and polish it down. I'm thinking that should help considerably.
(I'll make the joke about polishing a t-rd, just to beat you to it.)
Now, WTF is up with the cast, double-hump piece on the underside (cylinder facing)?
Has anyone ever ported a set of these, and if so, can you grind that piece right down flush? If so, how does it affect compression?
AvdTHANKSance,
- Joey
AvdTHANKSance,
- Joey
