I am about to get started on my heads, just have a few questions before hand though. I am just wondering if any of you who port your own heads(preferably e7's) unshroud the valves. It seems as if there is both a benefit to it, but it does lower the compression ratio a little bit. Check out this info, http://www.geocities.com/jjonibones/Shrouding.html That is the process of how to do it, but if you go to the main page, and on the left side click head tune-up, it shows the flow test for it. Unshrouding the valves created a few more cfm at low lift, and then it stayed pretty much equal at higher lifts. So it would give more power at lower lifts.
Question though, is it worth it to do it? How much would it lower the compression? I wouldn't think it would lower it very much, but I wanted to check to find out. What would you guys recommend for this?
Thanks,
Chris
Thanks,
Chris
