  • SN95 4.6L Mustang Tech
Porting Lower Intake?
  • Thread starter Thread starter FastGT02
  • Start date Start date Feb 4, 2007
FastGT02
22
  • Feb 4, 2007
Ive got a friend who is a machinist and makes his living porting and polishing heads and intakes. I was wondering if it would even be worth while to have him port/polish the upper and lower stock intake manifolds for our 99+ cars? How much hp/torque can i expect from a job like this?
Jackie Chan
I didn't read this.
2,507
Orlando, FL
Feb 4, 2007
  • Feb 4, 2007
dont think i would try porting a composite intake.......
W
Will Smith
191
Cape Coral, FL
Feb 4, 2007
  • Feb 4, 2007
dito
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Feb 4, 2007
  • Feb 4, 2007
Can you port the lower intake,i know i can't with mine,being plastic/composite and all.
Now maybe the upper plenum is another story!
FastGT02
22
  • Feb 5, 2007
Im a moron, i wasnt thinking about the lower intake. However do you think porting a stock upper would be beneficial over a C&L or other aftermarket upper. Will an extensive port job outflow aftermarket?
R
RoadconeTuning
458
Upstate, SC
Feb 5, 2007
  • Feb 5, 2007
ported and aftermarket will be about the same... im using a spare plenum rihgt now to learn how to port stuff... ill see if it just screws up stuff or not
DropTopPony
Noob Slayer
2,570
south jersey
Feb 5, 2007
  • Feb 5, 2007
porting the stock plenum and using a intake spacer was popular before the aftermarket plenums came out but its easier to just buy a C&L or Trick Flow for $100...none of them get you more then 4 or 5 hp.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 5, 2007
  • Feb 5, 2007
You would probably show a little bit of low to mid range performance increase by porting the stock plenum, but something like the C&L plenum will give you a little more power all the way across the curve.
You have to be carful with DIY porting though, because aftermarket plenums are designed to give as laminar a flow as possible to the lower. You just have to be careful if you are going to attempt to do your own porting to the plenum that you don't disrupt this laminar flow.
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
