  • SN95 4.6L Mustang Tech
Porting PI intake? :)
  • Thread starter Thread starter geaux
  • Start date Start date Jan 17, 2009
G
geaux
49
Atlanta GA
Jan 17, 2009
  • Jan 17, 2009
I am bored so I just thought I would throw out a wild hare idea and see who shoots it first.
Couldn't you use a dremel to grind away that soft soft plastic and then use epoxy or jb weld or something to gasket match?
Would the fuel eat it up?
Would heat do it in?
Would it destroy the integrity of the intake, cause time/space warps or something.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jan 17, 2009
  • Jan 17, 2009
just get a pi intake, they can be bought for pretty cheap.......
G
geaux
49
Atlanta GA
Jan 17, 2009
  • Jan 17, 2009
That is what I have.
The question is can the plastic intake be modified to gasket match better.
The rabbit is still running next shooter.
98COBRA281
1,348
30
59
Jan 17, 2009
  • Jan 17, 2009
oops, i read it wrong.
yes, i did quite a bit of clean up work in my intake around the injectors, there was alot of rough plastic blobs in there.........
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 17, 2009
  • Jan 17, 2009
You cant port PI intakes in the traditional sence of making the flow better - you need some metal.
J
jprovence
195
Albany, OR
Jan 17, 2009
  • Jan 17, 2009
There is really nothing to port. The heads need far more work then the intake anyways.
G
geaux
49
Atlanta GA
Jan 17, 2009
  • Jan 17, 2009
You can grind away plastic just as well as you can grind any metal. If you grind through plastic you got the equivalency of welding to repair it. Stuff like epoxy and jb weld is also fluid and sets so it is easy to shape.
I am kind of playing devil's advocate because I have never heard of anyone doing this and pioneers usually get turned into arrow pin cushions.
Just curious WHY NOT?
G
geaux
49
Atlanta GA
Jan 17, 2009
  • Jan 17, 2009
The ports on the intake don't gasket match any more than do the ports on the heads. Granted the heads are aluminum with meat around the ports.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 18, 2009
  • Jan 18, 2009
Ask any mustang shop, they wont port a PI intake
G
geaux
49
Atlanta GA
Jan 18, 2009
#10
  • Jan 18, 2009
  • #10
Not surprised at that since working in plastics is not a mechanic or machine shop forte. Regardless of the material the intake is made of, gasket matching is beneficial. TRUE? The whole game is to present as smooth and unobtrusive path for the air to travel into the combustion chamber.
The wild hare is still zigging and zagging. Saying a shop will not do it is not saying why they will not. Next shooter please.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 18, 2009
#11
  • Jan 18, 2009
  • #11
In a word....no!
For starters, have ever tried to grind away plastic? It doesn't wear and cut like metal, it melts and clumps. It makes more of a mess than anything and is almost impossible to put a finish on.....and will constantly bung up your grinding bits. You'll probably have the most luck having the intake extrude honed, but even then, you'll never duplicate the smooth finish of the stock surface mould casting. I've heard of some shops sawing the lower running length of the bottom of the intake off, to tale a section of length out of the intake runners, then epoxying them back together in order to raise the power band a little, but from what I know they leave the surface of the runner walls themselves alone.
Besides.....as already stated, the stock PI intake isn't the flow issue when you start putting out big power numbers, its the heads.
G
geaux
49
Atlanta GA
Jan 18, 2009
#12
  • Jan 18, 2009
  • #12
Now that is what I am talking about Gearbanger. That logic and info wounds the wild hare idea severely.
Thank you.
Still kicking though.
I kind of agree it is a wasted effort and that gasket matching on the heads makes much more sense so the air isn't disrupted by the edge of the head ports.
I did a google search on the idea and on other vehicle plastic intakes they do it but more of a clean up than a gasket match and some use jb weld. Nothing about reaction to fuel or mechanical failure (cracking) mentioned.
Biggest problem is there doesn't seem to be much thickness to the walls of the intake. After the head swap I will have a NPI intake laying around so I might play with it just because.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 18, 2009
#13
  • Jan 18, 2009
  • #13
Understand though, the reason for the limited performance of the NPI intake is the small diameter runner size and their short length. It’s kind of a catch 22. There’s not enough "meat" around the walls of the runner to increase their volume to the point where they would be beneficial to top end performance and their short over all runner length hurts velocity and therefore low end torque which the 4.6L would otherwise desperately need.
I personally think you'll be wasting your time, but it is your time to waste. Just don't be too disappointed with the end result if it’s less than spectacular.
G
geaux
49
Atlanta GA
Jan 18, 2009
#14
  • Jan 18, 2009
  • #14
I agree but this is a gentlemanly theoretical discussion about the merits and the mechanics of porting plastic intakes.
I declare Gangbanger the ace shooter. This idea is dead.
mustangman9812
661
Mars Hill, NC
Jan 18, 2009
#15
  • Jan 18, 2009
  • #15
Waste of time and a perfectly good PI Intake if ya asked me........ O BTW lol Gangbanger LOL LOL, its Gearbanger lol.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 18, 2009
#16
  • Jan 18, 2009
  • #16
Shops wont do it for a reason, lol. It's not like they don't want to get paid. I like how many responses it took to convince someone trying to port 1/4" width of plastic it's not a good idea.
fasthippo
52
OC, CA
Jan 18, 2009
#17
  • Jan 18, 2009
  • #17
port it as much as you can and spray it. then tell us what happens.
248a
Phoenix, AZ
Jan 18, 2009
#18
  • Jan 18, 2009
  • #18
I'm sure after all that porting it could take a 200 shot no problem.
G
geaux
49
Atlanta GA
Jan 18, 2009
#19
  • Jan 18, 2009
  • #19
Hummm. Reminds of the time we got the visiting city kid to pee on the electric fence. No I am convinced I should pass on this rodeo. Just idle ideas.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Y
Dyno Comparison for TFS 44cc Ported Heads vs PI Ported Heads with same VT Stage 2 Cams
  • Yel2002GTAuto
  • Oct 13, 2022
10K
SN95 4.6L Mustang Tech Jan 29, 2023
Yel2002GTAuto
Y
J
  • JRC99
  • Apr 19, 2025
JRC99
J
