Porting PI intake? :)
geaux
49
Atlanta GA
I am bored so I just thought I would throw out a wild hare idea and see who shoots it first.
Couldn't you use a dremel to grind away that soft soft plastic and then use epoxy or jb weld or something to gasket match?
Would the fuel eat it up?
Would heat do it in?
Would it destroy the integrity of the intake, cause time/space warps or something.
You cant port PI intakes in the traditional sence of making the flow better - you need some metal.
You can grind away plastic just as well as you can grind any metal. If you grind through plastic you got the equivalency of welding to repair it. Stuff like epoxy and jb weld is also fluid and sets so it is easy to shape.
I am kind of playing devil's advocate because I have never heard of anyone doing this and pioneers usually get turned into arrow pin cushions.
Just curious WHY NOT?
Ask any mustang shop, they wont port a PI intake
Not surprised at that since working in plastics is not a mechanic or machine shop forte. Regardless of the material the intake is made of, gasket matching is beneficial. TRUE? The whole game is to present as smooth and unobtrusive path for the air to travel into the combustion chamber.
The wild hare is still zigging and zagging. Saying a shop will not do it is not saying why they will not. Next shooter please.
In a word....no!
For starters, have ever tried to grind away plastic? It doesn't wear and cut like metal, it melts and clumps. It makes more of a mess than anything and is almost impossible to put a finish on.....and will constantly bung up your grinding bits. You'll probably have the most luck having the intake extrude honed, but even then, you'll never duplicate the smooth finish of the stock surface mould casting. I've heard of some shops sawing the lower running length of the bottom of the intake off, to tale a section of length out of the intake runners, then epoxying them back together in order to raise the power band a little, but from what I know they leave the surface of the runner walls themselves alone.
Besides.....as already stated, the stock PI intake isn't the flow issue when you start putting out big power numbers, its the heads. :shrug:
Now that is what I am talking about Gearbanger. That logic and info wounds the wild hare idea severely.
Thank you.
Still kicking though.
I kind of agree it is a wasted effort and that gasket matching on the heads makes much more sense so the air isn't disrupted by the edge of the head ports.
I did a google search on the idea and on other vehicle plastic intakes they do it but more of a clean up than a gasket match and some use jb weld. Nothing about reaction to fuel or mechanical failure (cracking) mentioned.
Biggest problem is there doesn't seem to be much thickness to the walls of the intake. After the head swap I will have a NPI intake laying around so I might play with it just because.
Understand though, the reason for the limited performance of the NPI intake is the small diameter runner size and their short length. It’s kind of a catch 22. There’s not enough "meat" around the walls of the runner to increase their volume to the point where they would be beneficial to top end performance and their short over all runner length hurts velocity and therefore low end torque which the 4.6L would otherwise desperately need.
I personally think you'll be wasting your time, but it is your time to waste. Just don't be too disappointed with the end result if it’s less than spectacular. :)
