Porting?
  • Thread starter Thread starter 87gtconvt
  • Start date Start date Jan 29, 2004
87gtconvt
34
Wheaton IL
Jan 29, 2004
  • Jan 29, 2004
I just bought a ported upper and lower intake and it didnt say anything about polishing? Does porting and polishing go together, or do i need to find someone to do it? One of my friends said that if i dont polish them, it would disrupt the airflow and it would hurt my hp?
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jan 29, 2004
  • Jan 29, 2004
PM Tmoss...hes the man to ask
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Feb 1, 2004
  • Feb 1, 2004
Polishing does nothing for a ported intake.
SVT_97Cobra
347
PORTLAND TEXAS. 7 miles North of Corpus Christi
Feb 1, 2004
  • Feb 1, 2004
Correct me if i'm wrong but you really only want the exhaust ports polished. I have ported numerouse heads and have ported both int & exh. But I concentrate on the exhaust ports when polishing.
87gtconvt
34
Wheaton IL
Feb 1, 2004
  • Feb 1, 2004
Cool, thanks
bmo37
2,368
New Jersey
Feb 1, 2004
  • Feb 1, 2004
basically its there to ease flow, think about it water flows faster over an even surafce rather than a bumpy on. Same is true with air. your trying to make air enter and exit as effortlessly as possible, So to answer your question yes it helps. On an intake its not done that much but its benifical though, most port jobs on an intake they have to cut the intake open and after porting reweld it. Polishing is seen usually on heads the most (combustion chambers).
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Feb 1, 2004
  • Feb 1, 2004
87gt convt-got any pictures of your trunk?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Feb 1, 2004
  • Feb 1, 2004
polishing the chamber and exhaust is OK to do but don't expect measurable gains. If you get a chance or are interested do a web search on "laminar" flow in intakes. Basically if I can explain this right in a short sentance or two, a smooth surface places drag on the air pasing over it. Think of many thin layers of air from the wall to the center of the runner. The one closest to the wall has the most "drag" on it from the wall and the layer above that has drag placed on it by the first layer (becasue they are in intimate contact from layer-to-layer) and so on into other layers of the runner. With a rough surface, the air "tumbles" in the first layer or two and creates tumbling "air bearings" that break up the drag on the rest of the layers. So, having a slightly rough surface is better for the intake side. The exhaust is different because the gas is much hotter (less dense, less drag) and is being pumped out rather than drawn in (same reason intake valves are bigger than exhaust). Polishing the chamber reduces the chance of hot spots that can create detonation and it inhibits the formation of carbon buildup.
87gtconvt
34
Wheaton IL
Feb 2, 2004
  • Feb 2, 2004
If i had a digi camera i would, when i get one i will.... whenever that is
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
R
Electrical Act
  • Robman8028
  • Jun 15, 2025
Fox 5.0 Mustang Tech Jun 16, 2025
General karthief
