Possible Valvetrain Noise?
  • Thread starter Thread starter blue92lx
  • Start date Start date Jun 15, 2006
blue92lx
14
  • Jun 15, 2006
Having a little bit of an issue here. About 2 weeks ago I heard a fairly loud 'Clacking' noise coming from the drivers side valve cover/intake manifold area. I figured it's probably a loose rocker arm, so right now it's all apart. It has SVO 1.6 RR with pedestal mounts. I rotated the engine by hand and went through each set of Rocker Arms and they didn't have any play on the valvestem/RR contact point. Questions are:
a) Should I go through, loosen them all up and redo them (using shims if necessary)? Or is it not worth it?
b) What else could be the problem?
The engine is a 302 with Edelbroch Performer heads and something similar to an E-Cam (engine was built when I bought it.) if that helps any.
Thanks.
chobracobra
175
jersey shore
Jun 15, 2006
  • Jun 15, 2006
my car does the same thing when it is cold except it comes from the front of the passenger side valve cover. When i start it and when the idle dies down it clacks, like a slapping sound and as the engine gets hot it comeplety stops.
blue92lx
14
  • Jun 15, 2006
That sounds more like a lifter going bad. This one was doing it even after it's warmed up.
chobracobra
175
jersey shore
Jun 16, 2006
  • Jun 16, 2006
A lifter would slap like that? I always thought it was just the valve head making contact with the cylinder head. figured that once it once hot, all the metals expanded to where they should be. I want to know what turns out with yours.
woodyy24
290
illinois
Jun 16, 2006
  • Jun 16, 2006
Thanks.
i have this exact same problem!! pedstal mount 1.6 RRs and a clevite cam similar to an E-cam. the first time i opened up the driver valve cover and discovered numerous bent pushrods some only slightly bent one had a nice curve to it lol. so i replaced those with ford racing hardened pushrods, the noise went away for about a week then came back after i got passed 5500 rpm once!!. me and my buddy decided it was the lifters so i replaced those, and it did the same thing....a week later the noise came back. so i thought id put my stock rockers back on and once again the SAME thing. seemed like every time i touched my rockers it made a difference. but still thought it was a lifter noise again i changed the lifters with crane lifters and i got a pedstal shim kit, i went cylinder by cylinder and bolted the rockers down and added shims until the correct preload was on the lifters. same thing, goes away and comes back again. by now im fed up with it, i havnt found any metal shavings or sign of wear and it doesnt make my car any slower so i decided to let it go, until something breaks im not pulling that dam intake off again.
one question, does it do it when its cold? mine doesnt make noise until it gets warmed up.
woodyy24
290
illinois
Jun 16, 2006
  • Jun 16, 2006
i also think this might be my problem, my heads were machined and bigger valves put in, maybe the machine work is to blame
blue92lx
14
  • Jun 16, 2006
hmm. Thanks for all the input from everyone. I haven't pulled the lower intake off yet, but the push rods aren't bent. I'm thinking of pulling the lower intake and installing some new lifters since I'm half way there anyway. I'm just really dreading putting on the upper intake and not doing any work to it first, that'll just piss me off and everything would have been pointless. So we'll see if that helps with new lifters.
fidstang
307
South Lansing
Jun 16, 2006
  • Jun 16, 2006
I think just about all of the 5.0's have some type of valvetrain clatter. Mine does, but I'm not concerned with it. I have been going through some of the other post for this issue. I have a thought and it's just a thought. Has anyone tested their valve springs to see if they're all within tolerence of each other?
blue92lx
14
  • Jun 17, 2006
I agree with you about the valvetrain noise always being present, however, that's more of a ticking noise, this one was more of a clacking noise. If you know what I'm talking about, there's a difference.
woodyy24
290
illinois
Jun 17, 2006
#10
  • Jun 17, 2006
  • #10
yeah more of a pinging, like metal hitting metal?
i revved mine past 6k the other night, seems like the noise went away again and all i have is the swooshing from the roller rockers now, and it runs smoother
chobracobra
175
jersey shore
Jun 17, 2006
#11
  • Jun 17, 2006
  • #11
Yea I would the describe the clacking sound as being unique to normal valvetrain noise.
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
Resolved Noisy Valvetrain
  • PonyGTrider
  • Jun 15, 2024
5K
Fox 5.0 Mustang Tech Jun 19, 2024
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
