post rust removal
  • Thread starter Thread starter Fireman255
  • Start date Start date Oct 5, 2006
F
Fireman255
119
  • Oct 5, 2006
I am sandblasting (and it sucks) surface rust off the stang, it rusted after I had stripped it last summer and put a light coat of primer on it.
My question is is there omething I should wash it with prior to putting primer on it to keep from having a rust problem if there is any spores left behind
thanks
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Oct 5, 2006
  • Oct 5, 2006
there are wash primers, self etching primers, and epoxy primers. all are said to have better rust prevention than just urethane primer alone. urethane primer will absorb moisture, so if the car is ouside soaking up the rain, then the primer wont do much to protect the metal. epoxy primer would be a better choice.
call your local paint supplier and ask them. they have the best knowledge of their paint systems.
chillininnh
28
NH
Oct 6, 2006
  • Oct 6, 2006
Ideally you spray the car with what they call a direct to metal epoxy primer sealer upon completion of the sandblasting.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Oct 6, 2006
  • Oct 6, 2006
NO!! You must clean the bare metal before spraying with a good solvent such as "metal wash" or a similar product. Use lint free rags. Even after you primer, you should put some type of base coat on to prevent rust. Most, if not all primers will absorb moisture.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 7, 2006
  • Oct 7, 2006
Use some POR15 and put the primer on top of that.... after you clean it with some solvent.
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
