post you RWHP/RWTQ
See sig... kinda lousy numbers in my opinion... then again my car hasnt run "great" ever since i bought it... the dyno was one of those ones you can pull around on a trailer, it was at the hotrod supernationals 2 summers ago, dunno how big a diff that makes + or - in hp/tq. I NEED MORE MONEY!
95snoozer said:
those numnbers are really on 6 pounds of boost?
Thats what I said,.........the deal is it is pullied for 9 but i have only seen 6 at the most. So it might be moving more air than it sounds for only 6 psi. But I've heard thats good, it means the motor is breathing well. I was happy with the numbers, can't wait for a dyno run with a real blower.
yeah.. with the TFs it would register less boost than with say stock heads. I guess
so 9 pound pully eh? Maybe I will go centrifugul after all.
aftercooled? whats done to your short block?
finally got to the track, so far only 6 runs on two different days. But I can only get a 12.4 @113. Each and every run I do one thing or another wrong. Either bad launch or slow/missd shifts. I think with a good 60 foot, I could get close to 11's. I'm usually in the 1.99/2.0 range. But I'm mostly worried about my trap speeds, A little low for 400+RWHP. But then again the tune is all over the place. No idea now what I am making on any given run.
see the sig
Later
Grady
214 rwhp/277rwtq
Completely stock except the following bolt-ons......
MAC Eq. shoties, MAC pro chamber, MAC cat-back, ASP pullies, CAI, timing at 12*. middle of august in Fla.
312rwhp/438rwtq.... same mods as above but with 100 shot. done the same day as above.
Old setup...
260rwhp/290rwtq.... ported e7te's, f-cam, 1.6 fms rr's, typhoon intake, 75mm maf, 75mm tb, 30# injectors (a/f 13.5 to 1 with just fpr adjustments), NO CHIP, MAC Long tubes, prochamber and cat back. CAI, pullies timing at 10*.
on 100 shot only made 332rwhp/460rwtq......lots of blow by from 167k miles.
As for the list of stuff in my sig, those dyno numbers will be coming shortly on the new set-up.
220 sae hp / 288 sae tq;
pulleys, efi extender, mac o/r h-pipe, msd coil, stock timing.
coil was good for 1rwhp.. o/r h-pipe was good for 22rwhp.. efi extender was good for 11 rwhp... from a baseline of 186/260 sae
