Powdercoating Intake
  • Thread starter Thread starter 87GT 306
  • Start date Start date Nov 3, 2004
87GT 306
260
Springfield MA
Nov 3, 2004
  • Nov 3, 2004
Im going to be getting my GT-40 Intake powdercoated over the winter and was wondering if anyone knows what kind of coating they use for the Dodge viper intakes? Its like a flat-red coating that has somewhat of a rougher texture to it. Anyone know what it is?
jaidedeye
627
Goldsboro nc
Nov 3, 2004
  • Nov 3, 2004
its a wrinlkle finish.....
87GT 306
260
Springfield MA
Nov 3, 2004
  • Nov 3, 2004
So I should tell him I want a red-wrinkle finish coating?
jaidedeye
627
Goldsboro nc
Nov 3, 2004
  • Nov 3, 2004
yeah, it will look cool. actually, you can buy the stuff in cans.
87GT 306
260
Springfield MA
Nov 4, 2004
  • Nov 4, 2004
Will powdercoating the intake keep hot air in or out??? I've heard both.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 4, 2004
  • Nov 4, 2004
Ceramic coatings have excellent resistance to heat transfer -- and they're entirely different from powder coating. Powder coating won't significantly affect the intake's ability to pick up heat from the engine bay. Ceramic coating will.
For some reason the system won't let me make a new post replying to your question. So I'm gonna try editting this one....
If you were more specific in what you're trying to accomplish, it would be easier to interpret what this "will be good or bad for it?" means.
If achieving a cosmetic look similar to the Viper is your main goal, mimicking that with powder coating should work fine. I'd just ask to see a sample from the powder coater so you're absolutely sure of what you're gonna end up with. If your primary goal is trying to insulate the manifold from underhood heat to keep the intake charge cooler - ceramic coating is what you want, not powder coating.
With either coating, the piece has to be media blasted to bare metal. Powder coating is basically coating the piece in a colored plastic. The manifold is blasted, cleaned and then negatively charged. The plastic powder particles are positively charged. So when they're sprayed out of the gun, the electrostatic charge holds attracts the powder to all parts of the piece coating it evenly. The piece is then baked to around 300-350F to 'melt' the plastic - both smoothing it and letting it completely bond with the metal. It's a very tough finish that stands up well under the hood. But it's only good for about 300F (can't use it on exhaust headers for example), and it doesn't provide thermal insulation.
The process of preparation/application is similar for ceramic coatings. Piece is blasted/cleaned (usually heated to 400F to thermally clean and remove oils), then the coating is sprayed on just like paint (no electrostatics involved). Headers are often coated inside and out. The piece is then baked at temps up to 700F degrees to cure the coating. Different chemical composition coatings are available for different temperature ranges - 800F for engine parts, suspension pieces, brake calipers; 12--1400F for most exhaust components; 2000F for extreme temps (piston tops, combustion chambers, boosted exhaust components, etc. There's not NEARLY the color choice for ceramic coatings that there is for powder coating. These coatings are EXTREMELY durable resisting physical abrasion, chemicals, and temperature. They will help keep your intake from absorbing or radiating as much heat as it would with a plastic coating.
Having said all that - I have no idea what type of finish the wrinkle finish on the Viper's intake is - paint, ceramic coating or powder coating. Without knowing that, it's impossible to know if that type finish will accomplish what you're trying to accomplish.
Did that help clear up your confusion?
Something's wrong with this thread - it won't let me post a new response - it gives me the 30 second too-soon-post warning each time. See this pic - this type of silver finish is the most common; but they do come in different colors.
http://www.corral.net/photopost/data/500/30684headersnewandold-med.JPG
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Nov 4, 2004
  • Nov 4, 2004
Thats a great explanation Michael. Can someone put up some pictures of this finish?
How much does powder coating an intake usually go for?
87GT 306
260
Springfield MA
Nov 4, 2004
  • Nov 4, 2004
Im confused. Are you saying that the wrinkle-finish that I want to get for the intake will be good or bad for it?
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
Nov 4, 2004
  • Nov 4, 2004
On a GT -40 I think it will look like crap... Kind of weird wrinkly looking think. I'd consider just powdercoating it and you valve colors at the same time the same color to keep it even. Not sure about price, expect to pay tops around $100 per peice
Jamie
87GT 306
260
Springfield MA
Nov 4, 2004
#10
  • Nov 4, 2004
  • #10
That cleared it all up. Thanks for the explanation Mike. As for the intake, I am going for more cosmetic than anything. I just think it would be different but I really think it wouldn't look too bad. I'd like to get the GT-40 top plate, upper, and lower red and then sand down the heatsinks at the end of the GT-40 intake to the bare aluminum. It would be something different. Im going to see if I can find any viper forums tonite and see if I can get an idea of what dodge uses on that intake. I attached a pic of what I'm trying to do but the finish is way too shiny for me.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Nov 4, 2004
#11
  • Nov 4, 2004
  • #11
I wanna see this wrinkle finish on the viper intake...i need to do something with my Holley intake. hmmmmm.......
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 4, 2004
#12
  • Nov 4, 2004
  • #12
87GT - I'm with ya; all that matters is how you think it looks. Go for it. I'm much more into paint and flat that chrome and glossy myself. Underhood on mine is black, gray, silver with a touch of red (dist. cap, wires, looms).
jaidedeye
627
Goldsboro nc
Nov 4, 2004
#13
  • Nov 4, 2004
  • #13
here is ceramic coating
http://www.MyOnlineImages.com/Members/jaidedeye/images/100_0543.JPG
87GT 306
260
Springfield MA
Nov 4, 2004
#14
  • Nov 4, 2004
  • #14
It looks really sharp. I want to get it on the valve covers, and intake. Like Mike, I'm not into the whole chrome and shiny scheme. I've got red spark plug wires, cap, pulleys and my msd box along with all the other black and gray.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 4, 2004
#15
  • Nov 4, 2004
  • #15
I had to log out and log back in to post in the thread. First link is ceramic coating on my headers; second is engine compartment. Edit - well, that won't work anymore. I'll try and get them posted here.
payupsucka
324
Keeping it grimy in Fall river MA.
Nov 5, 2004
#16
  • Nov 5, 2004
  • #16
any one from around south eastern mass if you want stuff powedercoated i can do it at my work only colors i have are gloss black flat black silver gray and an aluminum silver also i can do all of those colors in a wrinkle finish as well lemme know people oh and for stangers
free of charge just by me a coffee at dunkin donuts and we are square
M
mackey
1,284
Beverly, Massachusetts
Nov 5, 2004
#17
  • Nov 5, 2004
  • #17
Really? Looks like you are going to get alot of business from me. Where do you work? I go to School In Boston.
payupsucka
324
Nov 5, 2004
#18
  • Nov 5, 2004
  • #18
fall river
NosPony
278
Canton, Il
Nov 5, 2004
#19
  • Nov 5, 2004
  • #19
Darn glad I work at a shop that powdercoats. I got my intake and valve covers done for about 10 bucks. All my front suspension was only about 15 bucks to do. If anyone around me wants stuff done for a resonable fee let me know.
87GT 306
260
Springfield MA
Nov 8, 2004
#20
  • Nov 8, 2004
  • #20
Alright I'm pretty sure I'm getting it done in a month. Do they clean the intake entirely before they coat it( Inside and out )? They'll probably know not to coat the inside right? I just ask because I remember reading about a guy who chromed out his motor and the people chrome plated the inside of the intake and it caused problems.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
