power chip
  • Thread starter Thread starter meric0786
  • Start date Start date Oct 14, 2004
M
meric0786
Banned
Sep 17, 2004
  • Oct 14, 2004
i need to know if this is true i never even heard of this so if it is i will buy it and check it out
New
Gain up to 20 horse power
100% SAFE, 100% LEGAL!!
Does not void factory warranty
No tools required
Installs in under 10 minutes a kid can do it
LIFE TIME Guarantee
Accelerate faster and a higher top end
Comes with instructions for installation
Heat resistant and water proof
Slides Right In To Factory Sensor No Need to Solder or Cut Factory Wiring
All vehicles have an Electronic Control Unit (ECU)-a computer chip that electronically manages and monitors your car's performance-that is made according to government regulations. That means that your car could be going a lot faster and getting more power if you replace the ECU. That could cost up to 2000 dollars. This mod will modify your stock ECU with a Zoom performance chip. This mod connects to the car's ECU by replacing the Intake Airflow Temperature (IAT) Sensor. Once the module is installed, the ECU will read that the air coming in through the intake is cold air; think of it as a "default" setting on the ECU. When the ECU reads this, it leans out the air/fuel mixture-in other words, it will take in more air, and then add more fuel to compensate for the extra air coming in, thus, producing more power and advancing timing 1 to 2 degrees. Because the engine is creating more power, give your Car or Truck up to 20 More Horsepower!
This performance chip will work with all models of the vechicle in the title as long as the vechicle is fuel injected
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Oct 14, 2004
  • Oct 14, 2004
All that sounds like is a resistor that you put in the IAT sensor to make the sensor read wrong???
Ourobos
260
Oct 14, 2004
  • Oct 14, 2004
Right, think it's like 1 kohm? A $1.99 radio shack part.. Shy away from it..
A
autoXr1
1,838
Michigan
Oct 14, 2004
  • Oct 14, 2004
No, no, no, no, no.....Only a ricer would fall for that one. Any reputable tuner will tell you that there is little to be gained from "tricking" the ECU with these little gizmos and others like them...and may even harm the engine.
At certain part-throttle/cruise conditions and low load conditions, your engine is normally supposed to run at an air/fuel ratio that may be 15:1 or higher...all while being having the total timing approaching 40* or more. Basically, it's on the edge of spark knock. So, you put one of these things on...and guess what? Our ECU's have adaptive control...in other words, it will modify the fuel and timing curves to maintain the proper A/F ratio. Basically, cancelling out the effect of your little "mod". That's why adjustable fuel pressure regulators don't work over the long term...adaptive control...it just leans it out after a few hundred miles, or so.
At WOT, your car normally runs rich...like 12:1 in some cases. Those injectors are wide open. Nothing to be gained by such devices. Better off setting your initial timing up a few degrees and call it a day.
M
meric0786
Banned
Sep 17, 2004
  • Oct 14, 2004
wut about that throttle postion chip that jegs sells for like 90 bucks is that any good does anyone have it
A
autoXr1
1,838
Michigan
Oct 14, 2004
  • Oct 14, 2004
Looking for cheap horsepower, huh?
The only thing I can honestly recommend in the way of ECU performance upgrade is a dyno tune and ECU recalibration. Or, if you have the proper data logging and AFR monitoring equipment....a TwEECer, PMS, or the like. I don't know of any serious performance enthusiast or racer that is using these little gizmos...which says a lot...they probably don't work in the long run...ECU adaptive control. Save your money and do it the right way.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
  • dan50
  • Jul 18, 2026
dan50
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
