i need to know if this is true i never even heard of this so if it is i will buy it and check it out
New
Gain up to 20 horse power
100% SAFE, 100% LEGAL!!
Does not void factory warranty
No tools required
Installs in under 10 minutes a kid can do it
LIFE TIME Guarantee
Accelerate faster and a higher top end
Comes with instructions for installation
Heat resistant and water proof
Slides Right In To Factory Sensor No Need to Solder or Cut Factory Wiring
All vehicles have an Electronic Control Unit (ECU)-a computer chip that electronically manages and monitors your car's performance-that is made according to government regulations. That means that your car could be going a lot faster and getting more power if you replace the ECU. That could cost up to 2000 dollars. This mod will modify your stock ECU with a Zoom performance chip. This mod connects to the car's ECU by replacing the Intake Airflow Temperature (IAT) Sensor. Once the module is installed, the ECU will read that the air coming in through the intake is cold air; think of it as a "default" setting on the ECU. When the ECU reads this, it leans out the air/fuel mixture-in other words, it will take in more air, and then add more fuel to compensate for the extra air coming in, thus, producing more power and advancing timing 1 to 2 degrees. Because the engine is creating more power, give your Car or Truck up to 20 More Horsepower!
This performance chip will work with all models of the vechicle in the title as long as the vechicle is fuel injected
New
No tools required
LIFE TIME Guarantee
