- Jan 22, 2004
- 27
- 0
- 1
I Am Getting A Dyno Tune On The 28th, What Do You Guys Think I Will Put Down? I Live In Ca And Only Have 91 Octane. My Mods Are In My Sig.im Looking For 420rwhp.possible?
i know, i am in cali too. and i can only get stage 1 cams or i'll fail the sniffer. but i was just wondering how he got so much boost without special blower cams. and i was told you can't run that much boost here and stay legal.GinoGT said:He's in CA though, bunch of environmentalist Nazis over there.More than a "stage 1" cam would probably fail you in the sniffer in any state.
1990StangLX said:well i thought if you ran cams with lower compression you could run more boost, so i thought that with his 15lbs of boost he would have to be running blower cams, to lower the compression enough. but i am a newb to all this and still figureing it out![]()
) on a Novi blower (intercooled) car with 12psi. I forget if it might have been a stroker or not.You should blow 420 rwhp right out of the water at 15 psi. I'd say closer to 475. Good luck.kozumasbullitt said:I Am Getting A Dyno Tune On The 28th, What Do You Guys Think I Will Put Down? I Live In Ca And Only Have 91 Octane. My Mods Are In My Sig.im Looking For 420rwhp.possible?
ahhhhhhhhhhh ok so cams don't affect compression...interesting...so if i wanted to lower my compression to run more boost, i'd need pistons with more "dish" to them right?GinoGT said:
Piston shape (dish) is one way to control compression, cams have absolutely nothing to do with that. Get a piston with more dish (more of a "crater"-like shape) and that will lower compression, everything else being equal. Less compression does let you run more boost. Cams specifically designed for a supercharger or turbo usually give BIG gains over stock cams though. I believe VT Engines gained about 87RWHPshock:
Ask the guy from VT Engines, he'll tell you everything you would ever want to know.damn they only go to 2500 rpm? wow! that makes me think you could possibly run more aggressive cams couldn't you?kozumasbullitt said:stage 1 is all i can go in ca.the boost doesnt matter for smog because they only take the engine to 2500rpm
