After my 88GT warms up and goes into closed loop mode, the car loses power in the higher rpms. When cold, it pulls all the way to redline, but when it goes into closed loop, it almost feels like weak spark in the higher rpms or valve float, but that doesnt make sense only when warm. It's definitely a computer control issue because I can turn the car off and turn it right back on and the problem goes away for a couple of minutes. I've changed the TFI module, distributor, spark plugs, wires, ignition coil, cap/rotor, oxygen sensors, and coolant temp sensor. Please help!!!!
