Predator Data logging and TPS Question...
Ok so I have been fighting some trouble codes (1131 and 1151) that are on a different post.
So I was playing with the datalogging on my predator to see if I could see what might be causing them and something I noticed is that my TPS value was either nothing or WOT even with the slightest touch of the pedal.
What values would I see for TPS when using a predator and data logging?
Is nothing or WOT the only two values or could my TPS be messed up?
I also one of my O2 sensor's values going back and forth from on and off. Which I think might be a failing O2 sensor which might cause the above codes.
~K
Mine reads the same. I was woundering the same thing but it just seems to be the way the predator displays the data. As far as the O2 goes, it should be switching voltage from above and below around .4-.5 volts. Meaning you should see it hit .14 volts, then .86 and so on. If the front O2's are doing this your fine. Rears should do the same but not as drastic of a change. You might be looking at the O2 heater circuit switching ON and OFF.
