Here shortly I will be breaking in the 306...what would you guys suggest on the break-in procedure?
I'm going to put in 10w-40 to break it in with to help with the initial lubricating properties for break-in. I was thinking, prime the system...crank it and set the timing and fuel pressure quickly after letting it idle for a few minutes. Then go out and make 4-5 pulls at 3/4 throttle up to about 4,500 rpm and then let off the gas, creating cylinder pressure and vaccum...
Thoughts, how did you break-in your engines...
Daily driver by the way...best way for longevity?
Thanks
Thanks
