Ok well on a cold start I get a pretty bad vibration felt in the car. Above 1,200 RPM it seems to go away cruising it goes away too, even if i am below 1,200 RPM. One of my friends seems to think it looks like the engine is missing below 1,200 RPM. Spark plugs are new, cap is clean, and rotor is clean. When I look at the crank its pretty stable I dont see the harmonic balancer doing anything but spinning (No wobble). I pulled the pcv valve and it was pretty bad looked like it had been in there since 94 the p/n sure wasnt fram or purolator i guess it might have been motorcraft. But yea i replaced the valve and grommet and the car definetly feels better but the vibration is still pretty abnormal. What do you guys think? Could it be the clutch causing this problem? Maybe its damaged because when I do like take off normally and at a low RPM it shakes a bit but if I raise the rpm to 1,500 or above it engages smoothly. Or could it be a bad coil? I Have no idea whats going on. thanks for any help guys.
