Pretty significant oil leak, where could it be coming from?
SN95StangMan
1,292
Lynwood, CA
The other night I was coming home and the freeway goes uphill at a pretty decent angle. So, I punched it and noticed a huge plume of smoke behind me. So i just cruised slowly home, I busted out the flashlight and noticed a lot of oil on the right side of my car. All the way from the header collector, to the bend on my side exhaust. Now, the amount of oil towards the back of the car wasnt as dramatic, but towards the front, there was enought that it dripped off of my x-pipe. I lookd in the engine compartment and noticed a pool of oil behind the lower manifold. I dont think the seal back there is bad. I was thinking maybe a bad vavle cover gasket, but that seems like a buttload of oil for just a valve cover gasket. I needed new valve seals on a few cylinders anyhow, so that is going to be replaced. Where else could all that oil have come from? I doubt it is the rear main seal, because the oil is splashed around as high as the header collector. That, and I just replaced the old leaky seal a couple months ago. Maybe the PCV popped out, but it seemed to be in tact when i looked under the hood...
any suggestions would be greatly appreciated. :nice:
Well maybe you have a bad muffler bearing:shrug: , no but seriously.. Iwould try to find the highest point there is oil. Lower intake manifold or valve cover are very possible.. If you suspect eather and still are unsure you can always clean them down with brake clean( engine cold!) or degreaser. Run the engine after doing so and inspect for oil seapage or leaks.
I was leaning toward that too, except for the fact that theres no oil whatsoever on the drivers side of the car. That may be because only that corner of the rear manifold seal is leaking though, couldnt it?? :shrug:
Are you seeing oil on the header primaries too? If so, then I would suspect the valve cover, which can spew quite a good bit of oil at WOT (I can attest on personal experience).
If not, then I am with the rest on the rear lower manifold valley seal. BTW, mine is bad too.
Please post up as you have luck finding it. I'd be curious.
If replacing valve cover gaskets, I would use the rubber over metal versions. Nice pieces that are reusable (they have ferrules in the bolt bosses to prevent distortion).
Good luck.
94GTLaserRC said:
:stupid:
Oil leaks suck....Im still chasing one from 2+ years ago :nonono:
RC
Heh, your situation was the first thing that came to mind when I was looking for this... :(
Im going to clean it up and see what I can find. It's just a pain in the a$$ to try to get a good look back there. I was definitely going to do the valve cover before I try doing the manifold again. Ill see if I can get some pictures of this...
Thanks guys. :flag:
Thanks guys. :flag:
I just got her up on the stands, and got underneath with a good xenon white light...Sprayed a ton of brake cleaner to get the oil off (with a fan blowing the air out of the garage) then took it from there.
RC
