Pro built 351W for sale
blueovalguy
1,364
York Haven, Pa.
351W (’86 truck block)– bored .030 over, flat top pistons with valve reliefs (9.5:1 CR), Edelbrock Performer RPM heads(194/160 valves), cam, lifters, intake, carburetor, Accudrive gear drive, truck rods, Scorpion 1.6 roller rockers, Comp Cams pushrods, guide plates, crank cut .010 under, new bearings thru-out, Milodon 7 qt. oil pan (with dipstick in front) and high volume oil pump, ARP head bolts, aluminum high flow water pump, Mallory distributor. Everything is brand new/unused except heads, (a few hundred miles on heads). Edelbrock signature valve covers and air cleaner. Heads are currently off the block for inspection. Short block was professionally prepped, balanced, blueprinted and built. Have receipts for over $4,000. Will take $2,500 complete. Must pick up.
__________________
