pro m mass air meter question
Man, I know this question has been addressed before, and I believe the answer was something like: Unless you have a way to modify the MAF transfer function or injector slope in the computer, then that's not a good idea. The stock MAF electronics are designed to work with the stock injectors, stock computer, and designated size MAF housing whether its the 55mm, or the 70mm.
You might get it to "work", but the computer is going to interpret some wierd signals, and chances are you're not going to get a good A/F ratio anywhere.
Besides, the "calibration" in Pro-M meters isn't in the housing like a C&L sampling tube, it's programmed into the electronics package...
:nice:
Well stated.
If the prom sensor has failed or is just plain missing, the housing needs to be sent back to prom.
They may be able to send you a replacement sensor, but you will have to contact them to see if that is a good idea or not.
Are you having trouble with your prom?
jason
