I purchased a set of LCA's from J&M last week and installed them on Saturday. Great looking arms
, no instructions
The arms were installed with the stickers toward the tires, this left the sway bar tabs on the inside edge of the arms. I installed the sway bar on the outside of the tabs thinking it was a change that was necessary. However, when mounting the sway bar this way, it was about 1/2" too wide--but it torqued down ok regardless.
I called J&M this morning and they said the stickers should go to the inside and the sway bar should be mounted on the inside.
For those with these arms installed, how did you install them? How is your sway bar mounted up (inside or outside), and did it have to be slightly pulled into place?
I noticed the sway bar hangs lower than it did before, but I assume this is normal.
Thanks,
Jeremiah
.The arms were installed with the stickers toward the tires, this left the sway bar tabs on the inside edge of the arms. I installed the sway bar on the outside of the tabs thinking it was a change that was necessary. However, when mounting the sway bar this way, it was about 1/2" too wide--but it torqued down ok regardless.
Thanks,
Jeremiah
