  • 1994 - 1995 Specific Tech
Problem setting timing need help
  • Thread starter Thread starter Yellow302
  • Start date Start date Jun 27, 2004
Yellow302
789
NJ
Jun 27, 2004
  • Jun 27, 2004
I have a problem setting the timing with my car.
The number keeps jumping from 10-40
I belive its because the spout connecter is stilll pluged in.
when i unplug it (car off)
the car will not start
so i plug it in and then it fires up. But i cant get a good reading because the computer keeps changing everything.
HELP!
HoofnIt
1,175
North Carolina
Jun 27, 2004
  • Jun 27, 2004
Start the car with the spout IN, when you get ready to set the timing, remove the spout.
Yellow302
789
NJ
Jun 27, 2004
  • Jun 27, 2004
wow thats hard Should have thought of that.
Thanks
Yellow302
789
NJ
Jun 27, 2004
  • Jun 27, 2004
well i unplug the wire coming out of the distributer and my car shuts off. I have no idea how to set my timing but i can do a head swap. im going to shoot myself in the face if I cant do this myself.
HISSIN50
34
129
Jun 27, 2004
  • Jun 27, 2004
i might try holding the throttle a little when unplugging the spout (get a friend).....maybe that will keep it alive.
where is your idle set at? codes?
good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 27, 2004
  • Jun 27, 2004
Sounds like you are unplugging the wrong wire. The wire is right near the mass air flow sensor (behind air filter). It has a long grey connector, and I think the wire is red, but not sure.
Scott
HoofnIt
1,175
North Carolina
Jun 27, 2004
  • Jun 27, 2004
You're not supposed to unplug the wire going into the distributor. The wire that contains the spout plug is attached to the harness that supplies the MAF sensor. Just fish around there and you should see the gray plastic housing.
RIO5.0
6,892
N.H.
Jun 27, 2004
  • Jun 27, 2004
no wonder it won't start...your unplugging the coil.... You need to find the Spout on the pass side fenderwell as mentioned...unplug it...start the car, set your timing, snug the bolt, recheck, shut it off, replug the spout...
The car should be warm or up to temp when setting the timing...
You'll get it...
HISSIN50
34
129
Jun 27, 2004
  • Jun 27, 2004
he must have been hangin out with fox people - our spout connectors are right off the TFI module on the dizzy.
RIO5.0
6,892
N.H.
Jun 27, 2004
#10
  • Jun 27, 2004
  • #10
Check the pic....right above where my MAF goes into the fenderwell...that group of wires...you can make out a Gray pc...Thats the spout....you an see a Yellow Zip-tie there....thats holds it when I remove it...no losing that mother...been there done that...
Yellow302
789
NJ
Jun 30, 2004
#11
  • Jun 30, 2004
  • #11
hehe ill be trying that tonight... again... Hopefully I'll unplug the right thing for once. LOL
Thanks guys
if i could get a better pic i'd apreciate it..
I think i found it though there are 2 grey box's once small with two red wire coming out of it.
Then there is a big grey box on the bottom.
94TURBO5 O
2,509
VA
Jun 30, 2004
#12
  • Jun 30, 2004
  • #12
It's less than an inch big and it plugs in same harness as the MAF and should be just hanging there. You're killing me with unplugging the coil plug
I don't run a spout and lock my timing @ 10 degrees and no detination or pinging anymore.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
G
Help with initial Microsquirt ignition setting
  • germain101
  • Nov 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Nov 15, 2025
Mustang5L5
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
