  • 1994 - 1995 Specific Tech
Problem Solved!!!!!
  • Thread starter Thread starter DFG 5OH
  • Start date Start date Sep 29, 2005
1 of 2 Next Last
DFG 5OH
1,341
Louisville, KY
Sep 29, 2005
  • Sep 29, 2005
I know this isnt exactly tech, but it could help people who are having similar probs.
As most of you know, i've been having lots of problems out of my car. All the test i ran came up fine. BTW the car dynoed at 150 RWHP and 228 ft-lbs tq.
I gave up, and took it to a shop. This guy knows mustangs, he drags them ect. It ends up, someone messed with my timing before i got the car, and really got it out of whack. He fixed it, and set it at 10* which is stock. When he test drove it, it pinged like MAD, so he brought it back, and set it to 8*. He said that if i got some plug wire dividers, instead of wire ties, that could help. He also said that the spount connector didnt read the right ohms, and he recocomended me replacing it. So i need plug wire dividers, a new spout, then i'll be able to set the timing to 10*. He said when he drove it at 10* it was WAY faster than at 8*...so i'm excited to get it totally done.
Anwyays, the difference is night and day, the car is a whole new animal...
WHERE CAN I GET A SPOUT AND HOW MUCH ARE THEY?
slvrbullit302
986
Alabama
Sep 29, 2005
  • Sep 29, 2005
congrats on gettin everything worked out.
DFG 5OH
1,341
Louisville, KY
Sep 29, 2005
  • Sep 29, 2005
its definatly a relief, hopefully this solves all my probs!
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Sep 29, 2005
  • Sep 29, 2005
Congradulations! So what is the spout supposed to read? And is it supposed to read the same at all times?
DFG 5OH
1,341
Louisville, KY
Sep 29, 2005
  • Sep 29, 2005
um i'm not sure justin, he just said it wasnt reading right, and i trust him...he bought Bob Glidden's thunderbird, and he's building a 500+ ci engine for it
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 29, 2005
  • Sep 29, 2005
It's strange that it pings at 10 degrees though. That's the stock setting, and a lot of us turn the base timing as far as 18 degrees advanced. It's good to know you got the problem sorted out though.
S/CBlack95GT
2,018
Tampa Palms, FL
Sep 29, 2005
  • Sep 29, 2005
You can get a spout connector at a junk yard or Ford, but good luck trying to explain what you are looking for. The original may have a part number on it if I remember right.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Sep 29, 2005
  • Sep 29, 2005
Yeah, you know how you go to the parts store .... then ask for a (common) part .... & they say they DON"T HAVE IT. Then you give them that "WTF look". Well, it'll be just the opposite for you this time, lol. They'll be giving YOU that look.
RIO5.0
6,892
N.H.
Sep 29, 2005
  • Sep 29, 2005
Good deal...sounds like a cheap fix....While back I pulled a kinda wacky code that was spout connected....could be what yours is???
All you need now is a AFR/Eddy/FTI combo to add 150+ ponies....
DFG 5OH
1,341
Louisville, KY
Sep 29, 2005
#10
  • Sep 29, 2005
  • #10
oh i've got heads/cam/intake, just need a few more parts I have no codes, he also adjusted the TPS, he said it wasnt exactly right...
CManT1914
3,172
Killeen, Texas
Sep 29, 2005
#11
  • Sep 29, 2005
  • #11
Geez! That's a lot of timing...
Matt, it's great to see you got your issues worked out. I don't know where you can get a spout though, other than a junkyard like somebody already mentioned.
HISSIN50
34
129
Sep 29, 2005
#12
  • Sep 29, 2005
  • #12
Half the Fords out there use SPOUT connectors - a J/Y will have plenty. A jumper wire works well too (some guys use a switch instead so they just toggle back and forth when setting timing. That is asking for a resistance issue with underhood heat IMHO).
Good luck.
DFG 5OH
1,341
Louisville, KY
Sep 29, 2005
#13
  • Sep 29, 2005
  • #13
thanks hissin!! and chris, my car is actually fun now
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Sep 29, 2005
#14
  • Sep 29, 2005
  • #14
Yeah, and check out THIS PREVIOUS THREAD. May give you a couple of ideas.
Starman
78
#15
  • Sep 29, 2005
  • #15
The spout connector can be gotten at a Ford dealer parts dept for about $3
I failed to plug mine back in years back and lost it. I used a small piece of speaker wire looped into a U shape with the ends stripped. All the spout connector is is a jumper that conncets the 2 leads in the harness and gives the EEC control over the dizzy.
If you're still pinging after doing all this, try replacing the ACT (Air Charge Temp) sensor that is in the rubber intake tube right in front of the shock tower.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Sep 29, 2005
#16
  • Sep 29, 2005
  • #16
I don't know that it would be a cause here .... but BTW he's referring to the IAT (Intake Air Temp.) sensor.
CManT1914
3,172
Killeen, Texas
Sep 29, 2005
#17
  • Sep 29, 2005
  • #17
I still remember when I first got my stang. It was real slow (lost to my dad's 01 F350 Turbo Diesel, lol) and it kept getting worse and worse. It got to the point where it wouldn't even spin the tires in the rain! Found out it was a MAF and replaced it, HOLY CRAP the car was 100000x faster! I thought it was the fastest thing in the world, lol. It was soooo much fun.
DFG 5OH
1,341
Louisville, KY
Sep 30, 2005
#18
  • Sep 30, 2005
  • #18
thats how my car was man. Mine still has more in it, after i get a new spout...i cant wait to bump the timing up more
SQUEEZE&STROKE
SOUTHERN CA
Sep 30, 2005
#19
  • Sep 30, 2005
  • #19
Since no one has mentioned it...I will take a stab at it. Have you checked your balancer? It could have slipped and what you think is 10* could really be 15 or 20. This happened to me...I was using a big wet unit and trying to retard my timing so it wouldnt blow up...well the balancer had slipped and what I thought was 8* was like 4*...it can slip either way...just give it a check. Hope this helps
DFG 5OH
1,341
Louisville, KY
Sep 30, 2005
#20
  • Sep 30, 2005
  • #20
thanks squeeze, my balancer is starting to show rubber, so its time for a new one i think anyawys. How could i tell if its "slipped"?
1 of 2 Next Last
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
