problem with 4th gear
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Mar 28, 2007
M
MattTheBat83
203
  • Mar 28, 2007
when i shift from 3rd to 4th or from 5th to 4th it grinds bad. this started all of a sudden. what are some of the problems this could be?
9
90bronconate
124
Phoenix, AZ
Mar 28, 2007
  • Mar 28, 2007
your syncro is toast
gunmetal5.0
144
Chico, CA
Mar 28, 2007
  • Mar 28, 2007
How difficult is that install?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 28, 2007
  • Mar 28, 2007
I have heard there is a good video to buy to do a t-5 rebuild and it is fairly simple.
gunmetal5.0
144
Chico, CA
Mar 28, 2007
  • Mar 28, 2007
Cool good advice i'm sure it could be found with a little looking. Do you have any idea what a kit would cost that could do the rebuild job?
Nibbie
127
  • Mar 28, 2007
(I am asuming you have a 5.0 mustang with a T-5 tranny) (I found one from -Danddperformance.com,T-5 rebuild kit, it sells for $209. Comes with bearings, races, blocker rings, springs, inserts, shims, thrust washers, and snap rings. Does not contain hard parts like gears, sliders or shafts. You can also go to summit racing and get a Ford racing performance parts T-5 rebuild kit for $249.95-should come with everything like the D&D kit.
Now you will also need tools for this, basic hand tools, snap ring pliers, dial indicater, I think i used a feeler gauge. and a shop press to press the some gears off to get to all the pieces you need to get to, it wont make sence to fix 3rd and 4th when you can also do 1st, 2nd and 5th. The tear down aint to hard, just putting everything backtogether is a little pain if you dont remember where everything go's. Get some specs on the transmissino also and make sure everything is within spec or that tranny will not last to long. if there was a scale from 1-5 (5 being hardest) i would give this a 4. If you do this on your own good luck
***with the grinding issue make sure your clutch is pressed down all the way, that has happend to me lol, and yes it is possably a syncronizer gone bad, lost its friction material and it cant slow the shaft down fast enough, so your slider pushing on that certain gear, gears aint grinding its your syncro and dog-houses (teeth) grinding*** oh i hope that made sence
gunmetal5.0
144
Chico, CA
Mar 28, 2007
  • Mar 28, 2007
Great advice nibbie this helps me also. So it's likely from what you're saying that if this install was done right it would fix his issue unless of course the gears themselves were shot. Sounds like a cost effective solution to getting a new or rebuilt tranny. If you get the video it sounds like it will make keeping track of the order of parts coming in and out will be easier. I would just write down the part as it came out in order so that when I went to reinstall it would be the reverse order because putting everything back together in the right order seems like the crucial step.
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
C
Trans issues.
  • ChrisCruz1972
  • Aug 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
slow84lx
C
Resolved Dead speedometer... not odometer gears or trans speed sensor 4R70 W
  • cobramoneypit
  • Jul 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 22, 2026
cobramoneypit
C
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
