Maybe you guys here can help me. I just rebuilt my 5.0 out of my '92 GT over the past two months, and now I'm having trouble getting the thing to idle. Here's a little background on the car though. For WHATEVER reason, the previous owner put a 5.0 out of a '71 Torino or Fairlane in the car, with the '92 fuel injection. The engine had been rebuilt, rather poorly I might add, I think in '08. It's bored .030" over, and the crank is ground down for .030" oversized bearings. Obviously the cam wasn't a roller, but I decided to do a roller convertion with an f-303 cam and lifter package and the correct length pushrods from Edelbrock. I have the timing set for 10* BTDC with the spout out, and I've quadruple checked the firing order. Everything on that end seems to be in order.
Anyway, the car will start (you do have to mess with the gas pedal a good bit to get it to do so) but it won't run under about 1000 rpms. I hooked up my vacuum gauge to the manifold, and nothing even registers under 1k. Once I get up to 1500 rpms and above, I'll have around 15-17psi when I let off the gas. It runs like a champ above 1500 rpms too. I have seen the surging idle check list that's floating around here, but that seems to be for a slightly different problem then what I'm having since I can't get it to run without playing with the gas. I've also checked for vacuum leaks probably 5 seperate times now. Do i need to reset the throttle plate in the throttle body and the TPS? Or should it atleast idle some, without any fine tuning? Not sure exactly what to do. Hopefully you guys can help. I look forward to any replys, I definitely appreciate it.
- Spencer
- Spencer
