problem with my TPS?!?
  • Thread starter Thread starter beaver2489
  • Start date Start date May 11, 2004
beaver2489
503
st. joseph missouri
May 11, 2004
  • May 11, 2004
I tried setting my TPS voltage today on my new motor and the lowest I can get it is 3.06v ? wtf is going on here? I've set the voltage before 4 times with no problems. With this new motor I have a new throttle body, and its being wierd... Its the same TPS that I had on the stock motor. Heres what I did: turned the key on, put the RED voltmeter lead into the orange wire of the TPS, and the BLACK lead into the green wire, loosen screws and adjust...the lowest I can get it to adjust is 3.08? With the stock throttlebody I could adjust it to .97v no problem? anyone else have this problem with aftermarket throttlebodys?
Icepick
378
Ft Lauderdale
May 11, 2004
  • May 11, 2004
Same with mine, i just replaced it, much better.
beaver2489
503
st. joseph missouri
May 11, 2004
  • May 11, 2004
replaced the TPS or throttlebody? my throttlebody is a Power Products I believe, they come show polished and I got it off ebaymotors. To adjust the TPS voltage with this TB, you have to loosen 2 allen head screws on the TB itself, and not the 2 screws that hold down the TPS like you do with a stock TB...thanks man, I'll try replacing the TPS and see what happens
Z
ZERO-7
  • May 13, 2004
to set the tps, put the red lead on the green wire & the black lead onthe black wire w/ the key on accesory.
DADDYJUSTANG
213
MANDEVILLE,LA
May 13, 2004
  • May 13, 2004
Ditto
10HoleLX
257
Southern California
May 13, 2004
  • May 13, 2004
Key should be at "ON" position but NOT running
Icepick
378
Ft Lauderdale
May 13, 2004
  • May 13, 2004
The TPS, mine was at 3.5 volts at idle, I think that is basically telling the computer that i have the throttle pressed farther than it was which told the computer it didn't need help to idle because i was pressing the gas. Replaced the TPS, set the timing to 12deg, readjusted base idle, put in the new TPS and the idle is fine now.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
R
TPS
  • Redguy69
  • May 5, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 5, 2025
