Problem with steering column!
  • Thread starter Thread starter 86turbo
  • Start date Start date Feb 3, 2009
86turbo
183
Feb 3, 2009
  • Feb 3, 2009
Hey guys I need advice about my steering column. There is up/down side/side play in the steering wheel. I double checked the wheel is tight and not moving, the 4 nuts mounting the steering column itself are tight, the rag joint is brand new, new rack. I have the feeling this 170K+ mile steering column is worn out. Maybe one of the bearings is shot? I called around to the part places and they dont carry them. Does anyone sell a rebuild kit?
thanks,
Drew
p.s its on an 85 coupe
Modular2v
3,222
23
99
oklahoma
Feb 4, 2009
  • Feb 4, 2009
thanks,
Drew
Take all the plastic covers off from around the steering wheel. Remove the multifunction switch. There will be 2 7/16 bolts.....they will be as loose as a 10cent whore. Take them out, add some thread lock and put them back in tight! That will take care of the play!
LX302
Stanger
728
Bethlehem PA
Feb 4, 2009
  • Feb 4, 2009
Bingo!
86turbo
183
Feb 4, 2009
  • Feb 4, 2009
I found those (behind multi switch) and they were NOT loose. I took them out, put some locker on them and threw them back in. The up/down movement can clearly be seen in the front bearing with the shroud off.
Drew
warriorpluto
267
monroe.LA
Feb 4, 2009
  • Feb 4, 2009
i got this same problem. i got scared to a did my whole front end and the damn thing is still loose. lol
86turbo
183
Feb 5, 2009
  • Feb 5, 2009
the steering columns are a pita to take apart. Nobody seems to sell a bearing kit for them so I guess I can always try the bone yards. Are the steering columns from 79-93 all the same? I know the multifunction switch and stuff is dif but if I found a low mile from from a 92 (for ex) I assume I could NOT make it work...
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
T
Aftermarket Steering Column
  • Tas_Jak
  • Jul 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2025
Tas_Jak
T
84 Mustang Steering Column
  • gunnylama
  • Mar 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
gunnylama
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
