Hi, I have a 1996 GT and the coolant temp gauge doesn't work at all. I replaced the coolant temperature gauge return sensor and it still doesn't give any temperature readings. I know the other sensor to the right of the one I replaced is for sending readings to the computer for engine management so that shouldn't be the problem. I am not having cooling problems but I just want the gauge to work so I know that it's running in normal range.
What else can I check to figure out the problem. So far I have replaced the sensor, checked all fuses, and that all seems to be fine. Is there anything in the gauge cluster that could be bad? Everything else in the cluster works except the temperature gauge so I assume it's good. Any tips to point me in the right direction before I have to rip into the wiring?
Thanks.
Thanks.
