Problem, wondering the cause.
  • Thread starter Thread starter johnt785
  • Start date Start date Apr 25, 2004
johnt785
158
Wichita, Kansas
Apr 25, 2004
  • Apr 25, 2004
Ok, its getting worse as i drive the car. My car wont accelerate past 3000 rpm's when floored. Unless i leave my foot on the floor for a good 10 seconds then it will finally go past 3000 and jumps around 3500, but doesn't accel smoothly past 3000. At idle its at around 500 to 600 Rpms. I can't put my automatic in Reverse because the engine stalls and dies. It is realllll slow off the line and takes awhile to get up to 10 mph, kinda bumpy too. I can hear something whinning off the line when i accelerate. Anyway thats about all the information i can gather for you all. I have narrowed it down to the Torqe Converter. Anyone agree with my? Are these the signs of a bad Torqe Converter?
johnt785
158
Wichita, Kansas
Apr 25, 2004
  • Apr 25, 2004
Oh, one more thing. When i put the carin Nuetral and rev the engine it revs fine all the way. Only when its in drive it screws up and won't run smooth.
HISSIN50
34
129
Apr 25, 2004
  • Apr 25, 2004
hopefully, your namesake, Mr AOD will speak up (Mustang John)....but with the elimination you did, trans seems pretty likely. the trans does not have bands to adjust right? i dont think so. TV cables - i think they do. might be worth checking its adjustment, but be careful cuz it is real important and easy to misadjust, i think.
you are topped up on fluid right?
good luck.
HISSIN50
34
129
Apr 25, 2004
  • Apr 25, 2004
what happens if you start out in 1 (vs drive)?
*note, that info wont help me, but it might be useful to someone whom actually knows about aod's.
R
redterror302
895
Mertztown, PA or State College, PA
Apr 25, 2004
  • Apr 25, 2004
Yeah, I would check to see about the throttle cable, and see whether your throttle body is opening all the way. When there is no load on the engine(neutral), it is easy for the engine to rev. When you have it in drive, you have much more load on the engine. Just because you are mashing the gas as much as you can, does not mean that the throttle blade is opening all the way. Just a thought....
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
