Just when i thought everything was right... The clutch slips under heavy load... say in in 3rd going 25 and give it gas... it wont move rpms stay the same... i hear a little pop from under the car... it moves a little bit and does it again... the only thing i noticed that was weird when i reinstalled the clutch was slack in the clutch cable where it meets the clutch fork the clutch also felt realy weird at first...... is there any way to adjust it... do you think this is the problem.... But off the top of my head would slack in the line cause problems dissengaging... not the other way around... it runs fine most of the time...no oil leak from the rear main seal i replaced or anything... the fly wheel was resurfaced... new clutch disk, new tob, new rear main, new preasure plate... and i cleaned everything off with break cleaner... you think it jsut needs to be broken in more possibly... ive only put 100miles on it... and ive been going easy as hell
