Problems w/ idle on a 347 stroker!
xYoung347x
382
Im in desprite need of some help on getting my 94GT 347 stroker, Compcam XE274HR, AFR 185, Edel RPM, BBK LT headers, 30 injectors w/ 73C&L MAF, stock throttle body, to idle. It wont idle for nothing. Basically the whole engine is new, and the car sounds like crap. Please give me any diagnous(sp?), answer that you can possible think of.
You might have to check the TPS voltage, adjust your IAC(flat headed type screw on top of the TB) and re-check or correct your timing... also make sure your vaccume lines are attached correctly. :nice:
OFFHAND I forgot what the closed TPS voltage should be, I cant remeber which one is between the FOX and 94 platforms.
G-Luck.
PETE
