Problems with 2.3 staying running
Ciara99
12
I am new to this forum since this is my first 2.3. Problem is that the car starts and idles. If you put it in gear it dies, also if you let it idle long enough it will start shaking, sputter, cough and die. It also spit out like black carbon out the tail pipe. I have replaced plugs, wires, dist cap, and pressure regulator. Another question is do you need a special wrench to tighten dist or just try to fit my hand down in there? Any help would be great. I bought the car like this and trying to fix it with out pouring money into randomly replacing parts. Thanks
I would pull the codes before doing anything. The country boy jumper wire method and some careful counting will work in a pinch.
Based on the above, I replaced the MAP or baro sensor on my 89 2.3 a couple years ago and cured a similar problem.
I changed the fuel pressure regulator. It was bad and it at least starts everytime now just not for long. Also what and where is the IAC? I should have a code reader this weekend so I can pull some codes. Thanks for the help.
The timing is set correctly and I also changed the fuel filter. It still starts and runs for about 30 seconds then it acts like it just shuts off, like you turned off the key.
I thought mines was the cat. turns out its a couple hoses that are airlines that wore out along with some kind of piece that goes along the transmission... sorry i cant be much help cost me 75 at my mechanic to fix it car runs like a champ again.:D
