Problems with header Install
  • Thread starter Thread starter 50canuck
  • Start date Start date Apr 24, 2005
50canuck
35
Oakville, Ontario ,Canada
Apr 24, 2005
  • Apr 24, 2005
Driver side header went in OK, by attaching header to heads first, then doing the connection to cat pipe. but pass, side not same story, when attaching header first, collector doesn,t line up to good with cat pipe. Should I do cat to collector first, leave bolts a little loose then do header to heads? The flange bolts line up pretty good. Its a pain doing it without hoist.
thanks
notchback
1,950
St Clair Shores MI
Apr 24, 2005
  • Apr 24, 2005
NO !!!!!!!!!!
in case you didn't hear that....NOOOOOOOOOO!
they will leak for sure, bolt tight to the head, then collector to the h-pipe....
do whatever you gotta do to get it close, i use my feet, did you completely remove the entire exhaust?
cuz if you didn't you'll fight the mufflers too , trying to get h-pipe to header
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Apr 24, 2005
  • Apr 24, 2005
Bolt both headers to the heads before you try putting the h-pipe on EITHER collector.
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Did Bassani completely mess up the exhause flanges?
  • parish99
  • Jun 24, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 3, 2024
Mustang5L5
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
