  • 1994 - 1995 Specific Tech
Problems
  • Thread starter Thread starter Travis95gt
  • Start date Start date Aug 30, 2004
T
Travis95gt
12
  • Aug 30, 2004
Hi there, I am brand new to this board I just bought a 95 GT. I sold my camaro and bought the stang, It has Gt40p heads, professional products intake, Long tube Mac headers, H Pipe etc... 19lb injectors and different MAF. I changed the plugs wires and coil and it runs like **** sometimes still. SOmetimes you can go to leave at a light and let the clutch out and it wont rev you can put it right to the floor and it wont rev till you take a load off of it rev it up then let it out. But sometimes it will bog around 2000 and if you hold it wide open it will clean up some what but not 100%. Sometimes the car also just rips but not very often. It also seems like it has a hard time climbing to 5800rpm like it is working very hard. It has 4:10 gears etc...
Thanks
Any help is great.
Travis.
AznStanger3v
2,026
Northern VA
Aug 30, 2004
  • Aug 30, 2004
5 speed or auto???
leaks of either vacuum or exhaust can cause those syptoms.
T
Travis95gt
12
  • Aug 30, 2004
Its a 5speed. I can hear an exhaust tick could that be the culprate ? what should the fuel pressure be set at and what do you do to set it ?? As well would and intak leak cause that ? I think there is a possiblity of an intake leak betweent he upper and lower but nto sure.
AznStanger3v
2,026
Northern VA
Aug 30, 2004
  • Aug 30, 2004
if exhaust is ticking, then you have a good chance of a leak
if the intake is leaking between the U and L, then you might not even be able to hold an idle. Your car should feel reaaaaal doggish.
fuel pressure is set at 42. to set it, you need a FPR and guage
95YellowGTbeasT
605
South Carolina
Aug 30, 2004
  • Aug 30, 2004
is it in gear when you let off the clutch???
Nick
95BLKGT5.0
608
Auburn Washington
Aug 30, 2004
  • Aug 30, 2004
To check for an intake leak let the car idle and spray some starting fluid around the upper and lower if the idle changes revs up or trys to die the you might have an intake leak.
squall9393
534
Oceanside, CA
Aug 30, 2004
  • Aug 30, 2004
I third that conclusion about the tick if your sure it's from the exhaust. Otherwise if it's from the engine then it could be a lifter or something else maybe in the valvetrain.
I had the same thing happen to me though. Some days run good and then other days run like utter ****. Check the MAF sensor my friend. Hesitation and sputtering are cause by incorrect air signals being sent to the computer. The computer in turn gives incorrect fuel amounts and timing to the injectors. I changed the MAF and adjusting the timing and I'm good now. Does the CEL come on and if so is it on all the time or come and go?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 30, 2004
  • Aug 30, 2004
Travis.
Thats all I need to see
I like this new guy already
Looks like your getting some good help.
What I wanna know is *** Whats the story on the Camaro to Stang switch?
Later
Grady
go-stang5.0
2,244
Glenview,Il
Aug 30, 2004
  • Aug 30, 2004
As far as the symptoms everyones on the right track. But nobody mentioned that you dont make any power at 5800 rpm. Those heads with a stock cam (if you have a stock cam) probably makes peak power at around 4300ish. Our cars from the factory made peak power at 4100 rpm. That almost stock setup isnt very high winding, I would recommend shifting at 4500 rpms and give the valvetrain a bit of extral life while ytour at it.
WhiteDevil
2,717
San Diego
Aug 31, 2004
#10
  • Aug 31, 2004
  • #10
As far as the revving problem i would say the valve springs are probably the culprit. Out stock valve springs suck, and wear out easily with high rpm shifts. If the guy before you modded it he probably beat on it a little. My car was mint but after 25k of 6,000 rpm shifts i had terrible vavle float which made it reallly bad in the upper rpms.
T
Travis95gt
12
#11
  • Aug 31, 2004
  • #11
The check engine light does come on and off. As well I have a adjustable fuel pressure regulator. just wanted to know if I need to unhook a vacum line to it like on my camaro.
Thanks for all the help
Travis.
squall9393
534
Oceanside, CA
Aug 31, 2004
#12
  • Aug 31, 2004
  • #12
OMG dude. You've totally got my MAF problem. See if Auto Zone won't let you swap it there to see if it's culprit before you buy it. If not there's always refund cuz the part "didn't fit" The computer is guessing what's the right air/fuel mixture and the variable signals turn the light off/on.
T
Travis95gt
12
#13
  • Sep 1, 2004
  • #13
The check engine light goes on and off while driving. NOt flashing but comes on for a bit then goes off for a bit. I have a 75mm Mass air meter you think it could be toast ?
gcomfx.com
3,690
Republic, MO
Sep 1, 2004
#14
  • Sep 1, 2004
  • #14
Pull your codes.... just because the CEL light goes off, doesn't mean the codes go away.
Mine goes on and off if I leave my fuel pressure too high from spraying. I bet you are running rich.... pull the codes and you'll know.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 1, 2004
#15
  • Sep 1, 2004
  • #15
Why play the guessing game and just replace parts and hope it fixes the problem. Pull codes and know for sure.
squall9393
534
Oceanside, CA
Sep 1, 2004
#16
  • Sep 1, 2004
  • #16
Are you spraying though? Variable fuel pressure under a normal condition isn't good and is caused by something not intended. I'm sure he's not getting this by spraying or else he wouldn't be baffled and asking what's up. My car runs rich most of the time but doesn't through codes. Throwing codes constantly isn't a normal thing. Throwing codes when driving normally should by investigated. Somebody wanna suggest a starting point for him? I said the MAF sensor. Travis can you pull some codes for us under "normal" driving conditions.
T
Travis95gt
12
#17
  • Sep 2, 2004
  • #17
Do you guys just use those ****ty code readers from the parts store or what do you use ?
squall9393
534
Oceanside, CA
Sep 3, 2004
#18
  • Sep 3, 2004
  • #18
Yeah I got mine from Walmart. Little blinking light and a tone. Nothing you can't do with a multimeter.
O
injectors keeping up?
  • optionizerSS
  • Apr 4, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
optionizerSS
O
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
K
1995 GT Random Starting Issue
  • kfvintx
  • Jun 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2024
CAMTWO1070
