Proform fan
  • Thread starter Thread starter red87
  • Start date Start date Apr 13, 2011
R
red87
38
Carteret nj
Apr 13, 2011
  • Apr 13, 2011
I have a proform [pos} fan. the thermostatic control took a dump, my question is can i use a 185 on 170 off temprature sender mounted in the thermostat housing to control the fan? oops make that a 190 on 180 off i have a 180 degree thermostat.
HISSIN50
34
129
Apr 14, 2011
  • Apr 14, 2011
You might find that you have issue with the fan running nearly all the time once the car is up to temp. One generally wants a buffer between the t-stat being fully open and the fan coming on. E.g. for a balanced 180* t-stat (meaning it's fully open by 180*F), one could have the fan come on at ~198 -200 and go off at 188 - 190*.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Apr 14, 2011
  • Apr 14, 2011
I have a similar setup but I drilled and tapped a hole in the intake for the t stat. Works fine.
fox04
78
augusta, ga
Apr 14, 2011
  • Apr 14, 2011
i have the same fan and problem did awat with the whole thermostat setup on the fan itself an wired it to a switch works fine
R
red87
38
Carteret nj
Apr 15, 2011
  • Apr 15, 2011
Thanks for reply guys.
Engine Fan temp sensor location.
  • 7-UP BILL
  • Apr 3, 2026
Fox 5.0 Mustang Tech Apr 7, 2026
KRUISR
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
R
Engine Fox body doesn’t run hot until I start driving
  • Rose5oh
  • Mar 17, 2025
Fox 5.0 Mustang Tech Jun 7, 2025
limp
