I'm starting on a project car in the next few weeks..
I purchased a 2004 GT, with 31K miles.. It has a built 2 valve with worked over Patriot heads/comp 270AH cams, and a Reichard sheet metal intake with a Vortech T-trim. The car made 541whp @ 10psi.
It's fast, but, I'm not very happy with the lagtastic reichard/t-trim setup.. So, I'm going to be making some changes..
I plan on running a set of 4 valve C heads, with a ported 99 Cobra intake manifold, and I will be switching to a Novi 2000 blower. I've run the Novi before, and IMO, it's MUCH better than the t-trim that's on the car currently.
The block will remain as a built iron (Windsor) setup. It currently makes right at 9:1 C/R with the 2 valve heads, so, I expect a few tenths less with the 4 valve heads.. which works great for me, as I plan on running higher boost levels. Here's what I have so far for the conversion..
'99 4 valve C-heads
'99 Cobra valve covers
Stock cams, valves and retainers
Comp heavy duty springs (newer springs.. good for higher boost levels)
'99 Cobra intake manifold
'99 Cobra front timing cover
'99 Cobra timing chains, guides, tensioners and gears
Navigator water pump
03/04 Cobra oil pump and pickup tube
BBK twin 65mm TB
Griffin radiator
60lb injectors
Billet fuel rails
-6 fuel feed from the tank to the front
Block-
Windsor casting, .020" over
CP pistons
Modmax h-beam rods
ARP main and head studs
Felpro MLS head gaskets
Trans/rear-
Viper T56 (out of '06 Viper ACR)
Mcleod 8 bolt flywheel
Strange axles
Strange adjustable shocks
subframe connectors
Parts on order, or soon to be ordered..
Novi 2000 head unit and bracket/idlers for '99 Cobra
Precision 24x12x4" intercooler
3" polished aluminum tubing kit with 3 ply silicone and t-bolt clamps
Tial 50mm blow off valve
Stock L-maf with MAFia (blow through)
SFI bell housing for Viper trans
26 spline twin disc clutch (undecided on brand)
Chrome-moly SFI drive shaft for T56 swap
Battle boxes
'99 Cobra coolant crossover tube
'99 Cobra alternator
'99 Cobra long tubes
That's all that I can think of for now.. If anyone sees anything that I'm missing, feel free to add it.
I'll be adding pics/details as this swap progresses. I couldn't find any up to date how-to's on this swap, so I'll be making a "how-to" with the info obtained in this thread.
Travis
'99 4 valve C-heads
BBK twin 65mm TB
Griffin radiator
60lb injectors
Billet fuel rails
Block-
CP pistons
Modmax h-beam rods
Trans/rear-
Strange axles
subframe connectors
Battle boxes
Travis
