  • SN95 4.6L Mustang Tech
Project- 9's for 9K.. :)
  • Thread starter Thread starter Trav4011
  • Start date Start date Oct 15, 2007
  • 3
  • 4
First Prev 3 of 4 Next Last
whyask
735
Sacramento
Jan 15, 2008
#41
  • Jan 15, 2008
  • #41
oh post pics of the cage painted..?? if you can !
T
Trav4011
174
Jan 16, 2008
#42
  • Jan 16, 2008
  • #42
I'll have to get out to the body shop to get some pics.. I'll be trailering it back here soon.
superstang01
448
9
29
Kingston, On, Canada
Jan 17, 2008
#43
  • Jan 17, 2008
  • #43
i think it would be cool to see this car get into the 9's for 9k...goodluck!
T
Trav4011
174
Apr 24, 2008
#44
  • Apr 24, 2008
  • #44
So, I finally got around to my motor...
I had to brush a few cob-webs away, but, everything has been kept fresh in anti-rust bags/packaging, stowed away in my garage over the winter..
Mic'd everything today, and then installed the crank this evening.. At 60ft lbs on the 12mm main studs, and 45ft lbs on the 10mm main studs, with the bearing shells installed, I showed between .0012 and .0015" of clearance in the mains.. Should be just about perfect.. The rods should be around .0025-.003" if everything was machined properly.. So far, so good..
Pistons/rods go in tomorrow..
Travis
W
Will Smith
191
Cape Coral, FL
Apr 24, 2008
#45
  • Apr 24, 2008
  • #45
just look at what you have already..i see you have a comp cam 274 set of cams in there now with a .500 lift.... Since that is a PI motor you do know that the factory lift on these is .550 and maybe think about switch to a .550 lift cam like the 278AH or the 270AH...
BurningRubber
1,865
24
58
Apr 24, 2008
#46
  • Apr 24, 2008
  • #46
Hell yes that is a sweet sight...
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Apr 24, 2008
#47
  • Apr 24, 2008
  • #47
460hp on stock block = boom!
nice car though and good luck with the build!
T
Trav4011
174
Apr 24, 2008
#48
  • Apr 24, 2008
  • #48
I need to update my "list".. as it's much different now..
I have having MPH cut me a set of turbo cams.. the 274's came with the original motor/blower setup..
Travis
T
Trav4011
174
Apr 24, 2008
#49
  • Apr 24, 2008
  • #49
The stock motor never grenaded.. I never really ran it hard though.. maybe 2-3 times at the drag strip..
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Apr 24, 2008
#50
  • Apr 24, 2008
  • #50
do you mean block, or crank,rods & pistons, i alway thought a stock 4.6 block with some good internals could handle alot more then that
BennyBlown2v
1,233
Carmel, INdiana
Apr 24, 2008
#51
  • Apr 24, 2008
  • #51
He meant block as in shortblock/bottom end.
T
Trav4011
174
Apr 24, 2008
#52
  • Apr 24, 2008
  • #52
I'm confused..
The stock "block" will handle 1000+hp.. which is what we're shooting for..
The internals are being replaced with billet parts.. with the exception of the crank, which is a forged cobra unit..
Travis
98COBRA281
1,348
30
59
Apr 24, 2008
#53
  • Apr 24, 2008
  • #53
yeah, because i read in alot of places that the 4.6 is a stong block and can handle a lot more then that
deftsound
Apr 6, 2004
945
Texas City TX
Apr 24, 2008
#54
  • Apr 24, 2008
  • #54
Trav4011 said:
I'm confused..
Travis
No i meant the stock internals sorry for the confusion
blkhorse
345
Apr 24, 2008
#55
  • Apr 24, 2008
  • #55
hopefully on the low side of that, max is .0027
04GTMustang
348
Stafford
Apr 24, 2008
#56
  • Apr 24, 2008
  • #56
the stock internals can handle a good bit of horsepower what they cant handle is a lot of horsepower running a lot of boost. there are guys making 450rwhp on 14psi and they blow up and then we have hotmustang that was runnin 12psi on twin turbos and making 550rwhp and didnt blow. It is also in the tune.
there really isnt a true answer to what these things can handle yet.
crzyhrse99
259
Kansas
Apr 25, 2008
#57
  • Apr 25, 2008
  • #57
Thanks for the update, keep us posted . Looking really nice
the98stang
2,408
Clovis, CA
Apr 25, 2008
#58
  • Apr 25, 2008
  • #58
I thought the cast iron block (not internals) could only handle like 500-600 whp before cracking? I could be wrong...
T
Trav4011
174
Apr 25, 2008
#59
  • Apr 25, 2008
  • #59
When building a high HP motor, we never go by the manufacturer's specs.. It is necessary to go with slightly more rod and main clearance.. Since we don't expect 100k+ out of this engine, we sacrifice longevity for durability. The mains are kept reasonably tight, so we don't drop the pressure delivered to the rod bearings.. but, the rods need to be loose to allow for more oil between the bearing and crank pin.
Travis
T
Trav4011
174
Apr 25, 2008
#60
  • Apr 25, 2008
  • #60
The Windsor iron block will handle in excess of 1000+whp.. my aluminum block is "said" to be slightly weaker.. but, I don't really believe that.. I've seen several WAP blocks in the 1000hp range.. I think it's all in the block prep and build..
Travis
  • 3
  • 4
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
