Well everyone seems to be posting up their build threads and i figured id do the same, first heres the pics of the car
Day i got it,
After original installation of a few parts, maybe 20 miles after last pics
Now this is the teaser before i install all of the parts i have
Now for the parts i have
MM K-member (with 2-point brace)
MM Front Control Arms
MM Torque-arm (heavy duty)
MM Panhard Bar
MM XL Series Full-length Subframe Connectors
MM Coil-over Conversion Kits, Front and Rear
Coil-over springs (500/250)
MM Caster/Camber Plates
MM Aluminum Rear Lower Control Arms (extreme duty)
Bilstein HD series struts (MM3 race valving)
Bilstein HD series shocks (MM2 Race valving)
MM Aluminum Steering rack Bushings
MM Solid Steering Shaft
MM Bumpsteer Kit (adjustable outer tie-rod ends)
MM Strut Tower Brace
MM Front Swaybar Relocation Kit
Front Swaybar Bushings
Front Swaybar End Links
98 Front Spindles
Cobra Brake Booster
Cobra Master cylinder
Wilwood porportioning valve
Cobra Rear Axle-torsen ford lsd-3.73's
All Stainless braided brake lines
Cobra Brakes front and rear
Cobra R 17x9's
Hoosier road racing DOT's 275/40zr17
Race Harness Seats
Autopower Roll cage
Dart Iron Eagle Block
Probe Dominator 347 with i-beam upgrades
Forged gear drive
mechanical cam setup
billet steel flywheel
Pics to come in a few weeks when i install everything, let me know what you guys think.
Day i got it,
MM Panhard Bar
98 Front Spindles
Cobra Brake Booster
Cobra R 17x9's
Race Harness Seats
Autopower Roll cage
Forged gear drive
Nice list of upgrades though
