As the title states i have just started ordering new components for my second prodject.
Just won an auction on ebay for a set of new low compression 331 pistons (std bore). Couldn't pass them up.. 300 bucks for a new set of Forged Probe pistons..
This is coming from my mustang fund which i finally got a little money built up in again.
(sold stock motor, and a few other things sitting around)
Anyways here's my plans...
-Internally balanced 327 (all forged)
-Aluminum flywheel (i think.. haven't quite decided)
-Still hunting a dart or R block (probably go Dart sportsman)
-Sollid Roller Cam (plan on around 8000 Rpm shift point) Wanted to go hyd but was told I would be replacing lifters a lot with anything over 7000 rpms.
-Upgrading valves/valve springs for sollid roller cam...
-For now im gonna see what my s-trim can handle- hope to make around 17psi(look to upgrade later)
-Upgraded fuel system (already upgrade fuel rails Just need pumps and new line from the tank to the rails)
-And i haven't decided if i want to jump up to high impedence or not yet. Will have to look at my options.
Look to order the crank and maybe the rods later this week. hope to be done by spring...
Plans may change.. May find out the blower will put to much stress on the crank for those rpms? Hope not though. Haven't quite done all my research, but a lot of the details are based off cam and can be changed later so its not a loss and the structure will be there to make really good POWER..
Lets see if the stock tranny can hold this..
I predict 9's for you this spring.
