project no more drip rail
  • Thread starter Thread starter 68_blue_coupe
  • Start date Start date Jul 2, 2006
68_blue_coupe
  • Jul 2, 2006
well friday i decide to hack off the rotted drip rails on my 68 coupe. and i am going to leave them off. here are some pics. <br />
<br />
before i cut anything i put sheet metal scres threw the roof in to the inner structure to hold it on. then out came the sawsall and off it went. <br />
i hope to be able to finish it up this week it was to hot to work any more friday<br />
<br />
front before drip rail was cut off <br />
<br />
<img src="http://memimage.cardomain.net/member_images/9/web/609000-609999/609909_28_full.jpg" border="0" alt="" /><br />
<br />
from front wiht out drip rail<br />
<br />
<img src="http://memimage.cardomain.net/member_images/9/web/609000-609999/609909_27_full.jpg" border="0" alt="" /><br />
<br />
NO MORE DRIP RAIL <br />
<br />
<img src="http://memimage.cardomain.net/member_images/9/web/609000-609999/609909_26_full.jpg" border="0" alt="" /><br />
close up of the welds <br />
<br />
<img src="http://memimage.cardomain.net/member_images/9/web/609000-609999/609909_24_full.jpg" border="0" alt="" />
allcarfan
The Answer Man
2,458
North Atlanta
Jul 2, 2006
  • Jul 2, 2006
easy part is done...hard part is to come...grinding and making everything look straight. Good luck! - and keep ostin pics.
12sec67
1,301
San Diego, Ca
Jul 2, 2006
  • Jul 2, 2006
its one of the best body mods that i have done to my mustang. i only had one problem, once everything is done you need to make sure your window are adjusted perfectly and tight to the rubber or you'll hear some wind coming in. you can also forget about driving in the rain with the window cracked for air
xoxbxfx
3,959
Southlake, TX
Jul 2, 2006
  • Jul 2, 2006
good job...I did it on my 66 a while back..trying to straighten it up is a PITA
washMO66
1,000
Washington, MO
Jul 2, 2006
  • Jul 2, 2006
Done on mine, like the look.......
68_blue_coupe
  • Jul 2, 2006
im not to worried about getting it straight right now. all i am trying to do is get it welded up. then when it comes time to do all the body work then i will weld it so it is straight ans smooth.
SHIFTY101EASY
129
  • Jul 19, 2006
on average, how much would a shop charge for this "procedure" ??? one side is perfect, the other has some holes through it....i like the shaved look but hear its too hard to do yourself unless ur really skilled.....so any general estimates??? thanks
Edbert
3,548
32
109
Austin TX
Jul 19, 2006
  • Jul 19, 2006
Nice work, I'd like to see the finished product too. I have a vert so the drip-rail mod is done at the factory
12sec67 said:
you can also forget about driving in the rain...
I also have given up the idea of driving in the rain, but that was after months of rust remidiation. Decided right then and there that my car would not see a rainy day, lawn sprinklers are the most moisture my roads will see. Anything more than a 15% chance of showers and the 2005 gets the duty.
68_blue_coupe
  • Jul 19, 2006
im not worried about rain getting in the car. this will be a daily driver. if it rains i will make sure the window is closed tight. i have already done a water test and no water gets in the car with the windows closed. i was using a 2500 psi power washer and blasting it rigth at the top of the window. not a drop of water in the car.
i hope to have an update this weekend. i have made alittle progress. i had a problem with my welder so i had to wait for parts to come in to fix it. then i got a bad case of welders flash. and that put me out for about 1 week and wating for the parts is killing me.
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
Engine Common 'start/stall' issue
  • General karthief
  • Oct 25, 2021
Fox 5.0 Mustang Tech Oct 25, 2021
General karthief
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
Pro M Fuel Pump Hanger....thumbs Up.
  • Jason 302
  • May 10, 2017
6K
Fox 5.0 Mustang Tech Aug 15, 2019
michics
Iron Oxide, AKA RUST!!!
  • firemansam
  • Aug 10, 2011
2K
Classic Mustang Specific Tech Sep 24, 2011
firemansam
